I am working on a text classification problem where my input consists of news articles.
There are two text attributes; the title of a news article and the fulltext (ArticleText).
As part of my research i am investigating the effect of assinging different weights to the title and fulltext attributes. This is done in the "Process document from data" process with the property "Select Attribute and Weights". (I use TF-IDF weighitng)
I tested five cases of different weights: (4.0 Title, 1.0 ArticleText), (2.0 Title, 1.0 ArticleText), (1.0 Title, 1.0 ArticleText), (1.0 Title, 2.0 ArticleText), (1.0 Title, 4.0 ArticleText). Each weighting configuration in a different process.
I was hoping that the TF-IDF score of words originating from the title would be multiplied with the corresponding weight and the same for the fulltext. However no matter how i set the weights, the outputed document term matrices are all equal. Am i doing something wrong, or is there another way to achieve my goal?
I have attached a simplified proces, where the Title attribute has weight 4.0 and the articleText 1.0.
cheers,
Frank
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="523" width="845">
<operator activated="true" class="set_macros" compatibility="5.3.000" expanded="true" height="60" name="Set Macros" width="90" x="45" y="30">
<list key="macros">
<parameter key="TermMatrixPath" value="//RapidMinerRepository/ForReal/Data/TermMatrix/GEW500Text1GramNoBlackList%{TW}TW%{AW}AW"/>
<parameter key="StratifiedDataPath" value="//RapidMinerRepository/ForReal/Data/Dataset/GEW500TextWithoutSource"/>
<parameter key="WordNetPath" value="C:\Program Files (x86)\WordNet\2.1\dict"/>
<parameter key="TW" value="4.0"/>
<parameter key="AW" value="1.0"/>
</list>
<operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="165">
<parameter key="repository_entry" value="%{StratifiedDataPath}"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.000" expanded="true" height="76" name="ProcessTrainDocuments (2)" width="90" x="313" y="165">
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="4"/>
<parameter key="prune_above_absolute" value="999999999"/>
<parameter key="prune_above_rank" value="0.05"/>
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights">
<parameter key="ArticleText" value="1.0"/>
<parameter key="Title" value="4.0"/>
</list>
<process expanded="true">
<operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" name="Tokenize (4)"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.000" expanded="true" name="Filter Tokens (4)">
<parameter key="min_chars" value="3"/>
<parameter key="max_chars" value="999"/>
<operator activated="true" class="wordnet:open_wordnet_dictionary" compatibility="5.2.000" expanded="true" name="Open WordNet Dictionary (4)">
<parameter key="directory" value="%{WordNetPath}"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.000" expanded="true" name="Filter Stopwords (4)"/>
<operator activated="true" class="wordnet:stem_wordnet" compatibility="5.2.000" expanded="true" name="Stem (4)">
<parameter key="keep_unmatched_stems" value="true"/>
<parameter key="keep_unmatched_tokens" value="true"/>
<operator activated="true" class="subprocess" compatibility="5.3.000" expanded="true" name="Filter Clash Attributes">
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.000" expanded="true" name="Filter Weight Attribute">
<parameter key="condition" value="equals"/>
<parameter key="string" value="weight"/>
<parameter key="invert condition" value="true"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.000" expanded="true" name="Filter Batch attribute">
<parameter key="string" value="Fold"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.000" expanded="true" name="Filter Source Attribute">
<parameter key="string" value="Source"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.000" expanded="true" name="Filter PRID attribute">
<parameter key="string" value="PRID"/>
<connect from_port="in 1" to_op="Filter Weight Attribute" to_port="document"/>
<connect from_op="Filter Weight Attribute" from_port="document" to_op="Filter Batch attribute" to_port="document"/>
<connect from_op="Filter Batch attribute" from_port="document" to_op="Filter Source Attribute" to_port="document"/>
<connect from_op="Filter Source Attribute" from_port="document" to_op="Filter PRID attribute" to_port="document"/>
<connect from_op="Filter PRID attribute" from_port="document" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.000" expanded="true" name="Filter Tokens (5)">
<connect from_port="document" to_op="Tokenize (4)" to_port="document"/>
<connect from_op="Tokenize (4)" from_port="document" to_op="Filter Tokens (4)" to_port="document"/>
<connect from_op="Filter Tokens (4)" from_port="document" to_op="Filter Stopwords (4)" to_port="document"/>
<connect from_op="Open WordNet Dictionary (4)" from_port="dictionary" to_op="Stem (4)" to_port="dictionary"/>
<connect from_op="Filter Stopwords (4)" from_port="document" to_op="Stem (4)" to_port="document"/>
<connect from_op="Stem (4)" from_port="document" to_op="Filter Clash Attributes" to_port="in 1"/>
<connect from_op="Filter Clash Attributes" from_port="out 1" to_op="Filter Tokens (5)" to_port="document"/>
<connect from_op="Filter Tokens (5)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="ProcessTrainDocuments (2)" to_port="example set"/>
<connect from_op="ProcessTrainDocuments (2)" from_port="example set" to_port="result 1"/>
</process>
</process>
