This is a sentence.This is another sentence.Once upon a time.A glass of wine.
This is a false sentence.This is another sentence.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="5.3.000" expanded="true" height="60" name="Read Document" width="90" x="112" y="75"> <parameter key="file" value="c:\temp\sample.txt"/> <parameter key="encoding" value="UTF-8"/> </operator> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="112" y="165"> <parameter key="mode" value="linguistic sentences"/> </operator> <operator activated="true" class="open_file" compatibility="5.3.007" expanded="true" height="60" name="Open File" width="90" x="246" y="255"> <parameter key="filename" value="C:\temp\stop.txt"/> </operator> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.000" expanded="true" height="76" name="Filter Stopwords (Dictionary)" width="90" x="380" y="165"> <parameter key="file" value="C:\Users\james.hickman\Desktop\RTStopWordDictionary.txt"/> <parameter key="case_sensitive" value="true"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.000" expanded="true" height="94" name="Process Documents" width="90" x="514" y="210"> <parameter key="vector_creation" value="Term Occurrences"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize (2)" width="90" x="246" y="30"> <parameter key="mode" value="linguistic sentences"/> </operator> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Open File" from_port="file" to_op="Filter Stopwords (Dictionary)" to_port="file"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
