<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="5.3.007" expanded="true" height="60" name="Read Excel" width="90" x="112" y="75"> <parameter key="excel_file" value="/Users/mfarhadloo/Documents/engapps/Documents/SentimentAnalysis/Codes/Data/P5/Nouns/P5-BON.xlsx"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.3.007" expanded="true" height="76" name="Nominal to Text" width="90" x="246" y="75"/> <operator activated="true" class="text:data_to_documents" compatibility="5.3.000" expanded="true" height="60" name="Data to Documents" width="90" x="380" y="75"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.000" expanded="true" height="94" name="Process Documents" width="90" x="380" y="210"> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="100.0"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="112" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.3.000" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="165"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.000" expanded="true" height="76" name="Filter Stopwords (Dictionary)" width="90" x="112" y="300"> <parameter key="file" value="/Users/mfarhadloo/Documents/engapps/Documents/SentimentAnalysis/Codes/english-stop copy.txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:filter_by_length" compatibility="5.3.000" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="112" y="435"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <operator activated="true" class="text:stem_porter" compatibility="5.3.000" expanded="true" height="60" name="Stem (Porter)" width="90" x="112" y="570"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="5.3.007" expanded="true" height="76" name="Multiply" width="90" x="514" y="210"/> <operator activated="true" class="k_means" compatibility="5.3.007" expanded="true" height="76" name="Clustering" width="90" x="715" y="120"> <parameter key="k" value="20"/> <parameter key="max_runs" value="100"/> <parameter key="determine_good_start_values" value="true"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CorrelationSimilarity"/> <parameter key="kernel_gamma" value="0.5"/> </operator> <operator activated="true" class="cluster_distance_performance" compatibility="5.3.007" expanded="true" height="94" name="Distance" width="90" x="916" y="120"/> <connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Process Documents" from_port="word list" to_port="result 1"/> <connect from_op="Multiply" from_port="output 1" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Distance" to_port="cluster model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Distance" to_port="example set"/> <connect from_op="Distance" from_port="performance" to_port="result 2"/> <connect from_op="Distance" from_port="example set" to_port="result 3"/> <connect from_op="Distance" from_port="cluster model" to_port="result 4"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
