🎉Community Raffle - Win $25
Join and Win
Topology Optimization Different Results
User: "Anıl Türkseven"
Altair Community Member
Updated by Anıl Türkseven
Hi; I created geometry and ı wanted to create new topology geometry, but I got a mistake. My parameters;
-20*20*20mm Cube (Bottom and top have one mm thickness nondesign area so design area is 20*20*18)
- Material Inconel 718 ( E=168000, Yield Strength=980Mpa, Tensile Utilize Strength=1232 Mpa)
- Bottom surface is SPC, Top surface is uniform pressure (30Mpa)
Topology Optimization Setup;
- Stress Contain: 515Mpa (Safety Coefficient 1.9)
- Min Compliance
-Max Vol. Frac 0.4
I want to get at the image (c) geometry.
Can you help me?
1 - 2 of 21
    User: "NickZ"
    Updated by NickZ
    Hi Anil,
    Typically I wouldn't apply both a stress constraint and volume fraction constraint on the same model.
    Try these setups:
    Minimize Mass with the stress constraint
    or
    Minimize Compliance with Volume fraction constraint
    OP
    Hi Anil,
    Try these setups:
    or
    Thank you, Zagorski. I have a new question :) How can I change element density. I don't want see intermediate value. I want to only see 0 or 1. And last question; How can I see threshold value for topology optimization. Thank you very much again, best regards.
