<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Root"> <description>This learner creates a linear regression model allowing numerical predictions for the loaded data set.</description> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.005" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Polynomial"/> </operator> <operator activated="true" class="linear_regression" compatibility="5.3.005" expanded="true" height="94" name="LinearRegression" width="90" x="179" y="75"/> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model" width="90" x="380" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.3.005" expanded="true" height="76" name="Performance" width="90" x="514" y="30"> <parameter key="absolute_error" value="true"/> <parameter key="relative_error" value="true"/> <parameter key="relative_error_lenient" value="true"/> <parameter key="relative_error_strict" value="true"/> <parameter key="normalized_absolute_error" value="true"/> <parameter key="root_relative_squared_error" value="true"/> <parameter key="squared_error" value="true"/> <parameter key="correlation" value="true"/> <parameter key="squared_correlation" value="true"/> <parameter key="prediction_average" value="true"/> <parameter key="spearman_rho" value="true"/> <parameter key="kendall_tau" value="true"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="LinearRegression" to_port="training set"/> <connect from_op="LinearRegression" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="LinearRegression" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
