<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="execute_script" compatibility="5.3.008" expanded="true" height="60" name="Execute Script" width="90" x="179" y="30"> <parameter key="script" value="import java.nio.file.Files; import java.nio.file.Paths; import javax.swing.JOptionPane; JOptionPane.showMessageDialog(null, "File last modified: " + Files.getLastModifiedTime(Paths.get("C:", "Users", "username", "Desktop", "Test.txt")));"/> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
