<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros> <macro> <key>attribute</key> <value>a4</value> </macro> <macro> <key>number_of_classes</key> <value>3</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.005" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.005" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="work_on_subset" compatibility="5.3.005" expanded="true" height="76" name="Work on Subset" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{attribute}"/> <process expanded="true"> <operator activated="true" class="agglomerative_clustering" compatibility="5.3.005" expanded="true" height="76" name="Clustering" width="90" x="45" y="30"/> <operator activated="true" class="flatten_clustering" compatibility="5.3.005" expanded="true" height="76" name="Flatten Clustering" width="90" x="179" y="30"> <parameter key="number_of_clusters" value="%{number_of_classes}"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.005" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="name" value="cluster"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="rename" compatibility="5.3.005" expanded="true" height="76" name="Rename" width="90" x="447" y="30"> <parameter key="old_name" value="cluster"/> <parameter key="new_name" value="%{attribute}_discretized"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="replace" compatibility="5.3.005" expanded="true" height="76" name="Replace" width="90" x="581" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{attribute}_discretized"/> <parameter key="replace_what" value="cluster"/> <parameter key="replace_by" value="value"/> </operator> <connect from_port="exampleSet" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Flatten Clustering" to_port="hierarchical"/> <connect from_op="Clustering" from_port="example set" to_op="Flatten Clustering" to_port="example set"/> <connect from_op="Flatten Clustering" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
