<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.007" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="normalize" compatibility="5.3.007" expanded="true" height="94" name="Normalize" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Humidity|Temperature"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.3.007" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Wind|Play|Outlook"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.3.007" expanded="true" height="94" name="Nominal to Numerical" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Wind|Play|Outlook = sunny|Outlook = rain|Outlook = overcast"/> <list key="comparison_groups"/> </operator> <operator activated="true" class="normalize" compatibility="5.3.007" expanded="true" height="94" name="Normalize (2)" width="90" x="581" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Wind = true|Wind = false|Outlook = sunny = true|Outlook = sunny = false|Outlook = rain = true|Outlook = rain = false|Outlook = overcast = true|Outlook = overcast = false"/> </operator> <operator activated="true" class="weight_by_information_gain_ratio" compatibility="5.3.007" expanded="true" height="76" name="Weight by Information Gain Ratio" width="90" x="45" y="210"/> <operator activated="true" class="scale_by_weights" compatibility="5.3.007" expanded="true" height="76" name="Scale by Weights" width="90" x="179" y="210"/> <operator activated="true" class="k_nn" compatibility="5.3.007" expanded="true" height="76" name="k-NN" width="90" x="313" y="210"> <parameter key="k" value="2"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.007" expanded="true" height="76" name="Apply Model" width="90" x="447" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.007" expanded="true" height="76" name="Performance" width="90" x="581" y="210"/> <connect from_op="Retrieve Golf" from_port="output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Normalize (2)" to_port="example set input"/> <connect from_op="Normalize (2)" from_port="example set output" to_op="Weight by Information Gain Ratio" to_port="example set"/> <connect from_op="Weight by Information Gain Ratio" from_port="weights" to_op="Scale by Weights" to_port="weights"/> <connect from_op="Weight by Information Gain Ratio" from_port="example set" to_op="Scale by Weights" to_port="example set"/> <connect from_op="Scale by Weights" from_port="example set" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="k-NN" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Marius wrote:Hey,just let me know when your next break starts and I can explain it to you personally See you later!Marius
michaelhecht wrote:This performs better than direct application of k-NN with two neighbours, i.e. seems to work as expected.
Where do you guys hang out?Dortmund University?
