<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="5.3.007" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.3.007" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="30"/> <operator activated="true" class="generate_id" compatibility="5.3.007" expanded="true" height="76" name="Generate ID" width="90" x="313" y="120"/> <operator activated="true" class="multiply" compatibility="5.3.007" expanded="true" height="94" name="Multiply" width="90" x="447" y="120"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="581" y="30"> <parameter key="vector_creation" value="Term Frequency"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.000" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="180" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.007" expanded="true" height="76" name="Join" width="90" x="715" y="120"> <list key="key_attributes"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Join" to_port="right"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.007" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="original_text" value=""X this is a simple XY test text Y""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.007" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="120"> <list key="attribute_values"> <parameter key="original_text" value=""X this is another XY text Y""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.007" expanded="true" height="94" name="Append" width="90" x="179" y="30"/> <operator activated="true" class="nominal_to_text" compatibility="5.3.007" expanded="true" height="76" name="Nominal to Text" width="90" x="313" y="30"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="45" y="210"> <parameter key="create_word_vector" value="false"/> <parameter key="vector_creation" value="Term Frequency"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:cut_document" compatibility="5.3.000" expanded="true" height="60" name="Cut Document (2)" width="90" x="179" y="30"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"> <parameter key="text" value="X.X"/> </list> <list key="regular_expression_queries"> <parameter key="xes" value="X(.+)X"/> <parameter key="yes" value="Y(.+)Y"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_port="document" to_op="Cut Document (2)" to_port="document"/> <connect from_op="Cut Document (2)" from_port="documents" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_id" compatibility="5.3.007" expanded="true" height="76" name="Generate ID" width="90" x="179" y="210"/> <operator activated="true" class="set_role" compatibility="5.3.007" expanded="true" height="76" name="Set Role" width="90" x="313" y="210"> <parameter key="attribute_name" value="text"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.007" expanded="true" height="94" name="Multiply" width="90" x="447" y="210"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="581" y="165"> <parameter key="vector_creation" value="Term Frequency"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.000" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="180" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.007" expanded="true" height="76" name="Join" width="90" x="715" y="210"> <parameter key="remove_double_attributes" value="false"/> <list key="key_attributes"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Join" to_port="right"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="180"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
