Hi everyone,
I am facing a strange behavior of timestamps (or big numbers) in RapidMiner and RapidAnalytics when reading them from a PostgreSQL Database. I set up a very simple process, which only reads from the DB, sorts the resulting example set and stores it in the RA repository.
<process version="5.3.007">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_database" compatibility="5.3.007" expanded="true" height="60" name="Read Database (2)" width="90" x="246" y="30">
<parameter key="connection" value="mypsqldb"/>
<parameter key="query" value="select to_char('01.08.2012 01:01:00+00'::timestamptz,'DD.MM.YYYY HH24:MI:SS TZ') as zeit_string, '01.08.2012 01:01:00+00'::timestamptz as zeit_ts, extract(epoch from timestamp with time zone '01.08.2012 01:01:00+00') as zeit_epoch union select to_char('01.08.2012 01:02:00+00'::timestamptz,'DD.MM.YYYY HH24:MI:SS TZ') as zeit_string, '01.08.2012 01:02:00+00'::timestamptz as zeit_ts, extract(epoch from timestamp with time zone '01.08.2012 01:02:00+00') as zeit_epoch union select to_char('01.08.2012 01:03:00+00'::timestamptz,'DD.MM.YYYY HH24:MI:SS TZ') as zeit_string, '01.08.2012 01:03:00+00'::timestamptz as zeit_ts, extract(epoch from timestamp with time zone '01.08.2012 01:03:00+00') as zeit_epoch;"/>
<enumeration key="parameters"/>
<operator activated="true" class="sort" compatibility="5.3.007" expanded="true" height="76" name="Sort" width="90" x="447" y="30">
<parameter key="attribute_name" value="zeit_string"/>
<operator activated="true" class="store" compatibility="5.3.007" expanded="true" height="60" name="Store" width="90" x="648" y="30">
<parameter key="repository_entry" value="../ExampleSets/Test2"/>
<connect from_op="Read Database (2)" from_port="output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="result 1"/>
</process>
</process>
When I execute
select
union
union
directly from RapidMiner, everything seems fine and I get
When running the same process on the RA server, I get a different and obviously wrong result
I'm using Rapidminer 5.3.007, RapidAnalytics CE 1.3.007 and PostgreSQL 8.4.4. RapidMiner uses the DB connection I've defined in RapidAnalytics.
Does anyone have an idea of what is going on here?
Thanks for help,
LarsH
