Applying Triangular Distributed Load to a CLT Panel Using S-Timber
User: "Milan Marojevic"
Altair Community Member
Updated by Milan Marojevic
Hello Everyone,
I am seeking assistance on how to apply a triangular distributed load to a specific area of a Cross-Laminated Timber (CLT) panel using S-Timber software.
In my scenario, I aim to simulate soil pressure load on the panel. However, the panel is elevated 60 cm above the ground level, hence I do not wish to apply the load to that section. I want to apply this load only to the part of the panel that is situated below the ground level.
I have attached a photo to provide a better understanding of my situation.
Your guidance would be immensely helpful.
Best, Milan
1 - 1 of 11
    User: "Tayen Aguilar_20350"
    New Altair Community Member
    Updated by Tayen Aguilar_20350
    Hello Milan, thank you for your comment.
    What you are describing it's not currently possible using S-TIMBER, the workaround would be to define multiple Wall Panels, and manually step up/down the magnitude of each panel.
    With that said, it is possible to do it with one panel on S-FRAME only applying the load pressure wherever you want on the panel (below the ground level in this case)
    S-FRAME will deal with this in a more elegant and easy way, although it would be possible to represent the behavior in S-TIMBER.
    If you have any additional questions or want us to take a closer look, feel free to share any additional information/models with us at sframe-support@altair.com we'd be happy to help.
    Best,
    Tayen Aguilar
    Altair Support
