<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <parameter key="logfile" value="/home/harb/Documents/DATA/Conductivity/SOM_project/rapidminer/BW6_process.log"/> <parameter key="resultfile" value="/home/harb/Documents/DATA/Conductivity/SOM_project/rapidminer/BW6_process.res"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve BengwordenSouth6" width="90" x="45" y="30"> <parameter key="repository_entry" value="../data/BengwordenSouth6"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value="DEPTH"/> <parameter key="attributes" value="CALI|CONDUCTIVITY|DEN|GR|LAT|LN|NEUT|SN|SP"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.3.008" expanded="true" height="94" name="Replace Missing Values" width="90" x="179" y="30"> <parameter key="attribute" value="CONDUCTIVITY"/> <list key="columns"> <parameter key="CALI" value="average"/> <parameter key="DEN" value="average"/> <parameter key="GR" value="average"/> <parameter key="LAT" value="average"/> <parameter key="LN" value="average"/> <parameter key="NEUT" value="average"/> <parameter key="SN" value="average"/> <parameter key="SP" value="average"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="246" y="165"> <parameter key="attribute_name" value="CONDUCTIVITY"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="linear_regression" compatibility="5.3.008" expanded="true" height="94" name="Linear Regression" width="90" x="380" y="30"/> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model" width="90" x="514" y="30"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve BengwordenSouth6" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Linear Regression" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Linear Regression" from_port="weights" to_port="result 3"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
