<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_xml" compatibility="5.3.007" expanded="true" height="60" name="Read XML" width="90" x="45" y="30"> <parameter key="file" value="C:\Users\username\Desktop\test.xml"/> <parameter key="xpath_for_examples" value="//city"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="node()"/> </enumeration> <list key="namespaces"/> <parameter key="use_default_namespace" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.binominal.attribute"/> </list> </operator> <operator activated="true" class="set_macro" compatibility="5.3.007" expanded="true" height="76" name="Set Macro" width="90" x="179" y="30"> <parameter key="macro" value="i"/> <parameter key="value" value="0"/> </operator> <operator activated="true" class="loop_values" compatibility="5.3.007" expanded="true" height="76" name="Loop Values" width="90" x="313" y="30"> <parameter key="attribute" value="att1"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="%{loop_value}"/> </operator> <operator activated="true" class="text:write_document" compatibility="5.3.001" expanded="true" height="76" name="Write Document" width="90" x="179" y="30"> <parameter key="file" value="C:\Users\username\Desktop\output%{i}.xml"/> </operator> <operator activated="true" class="set_macro" compatibility="5.3.007" expanded="true" height="76" name="Set Macro (2)" width="90" x="313" y="30"> <parameter key="macro" value="i"/> <parameter key="value" value="%{a}"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Read XML" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
