awchisholm wrote:HelloPosting the XML of the process is usually the quickest way to get to where you want.regardsAndrew
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:process_document_from_file" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="165"> <list key="text_directories"> <parameter key="child" value="C:\Users\Anahid\Desktop\chat samples\sample1"/> <parameter key="other" value="C:\Users\Anahid\Desktop\chat samples\sample2"/> </list> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="1.0"/> <parameter key="prune_above_percent" value="90.0"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize (2)" width="90" x="112" y="210"/> <operator activated="true" class="text:filter_by_length" compatibility="5.3.000" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="213" y="120"/> <operator activated="true" class="text:stem_porter" compatibility="5.3.000" expanded="true" height="60" name="Stem (2)" width="90" x="315" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.000" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="450" y="30"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="store" compatibility="5.3.007" expanded="true" height="60" name="Store" width="90" x="514" y="300"> <parameter key="repository_entry" value="//Local Repository/data/res"/> </operator> <operator activated="true" class="x_validation" compatibility="5.3.007" expanded="true" height="112" name="Validation" width="90" x="380" y="75"> <process expanded="true"> <operator activated="true" class="classification_by_regression" compatibility="5.3.007" expanded="true" name="Classification by Regression"> <process expanded="true"> <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.007" expanded="true" name="SVM (Linear)"/> <connect from_port="training set" to_op="SVM (Linear)" to_port="training set"/> <connect from_op="SVM (Linear)" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <connect from_port="training" to_op="Classification by Regression" to_port="training set"/> <connect from_op="Classification by Regression" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.007" expanded="true" name="Apply Model"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.007" expanded="true" name="Performance"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="store" compatibility="5.3.007" expanded="true" height="60" name="Store (2)" width="90" x="514" y="30"> <parameter key="repository_entry" value="//Local Repository/data/Test1"/> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Process Documents from Files" from_port="word list" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="result 2"/> <connect from_op="Validation" from_port="model" to_op="Store (2)" to_port="input"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/> <connect from_op="Store (2)" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
