<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.007" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.007" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="120"> <list key="function_descriptions"> <parameter key="constant" value="1"/> </list> </operator> <operator activated="true" class="aggregate" compatibility="5.3.007" expanded="true" height="76" name="Aggregate" width="90" x="380" y="120"> <parameter key="default_aggregation_function" value="median"/> <list key="aggregation_attributes"> <parameter key="a1" value="median"/> <parameter key="a2" value="median"/> <parameter key="a3" value="median"/> <parameter key="a4" value="median"/> </list> <parameter key="group_by_attributes" value="|constant"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.007" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="aggregate" compatibility="5.3.007" expanded="true" height="76" name="Aggregate" width="90" x="246" y="120"> <parameter key="use_default_aggregation" value="true"/> <parameter key="default_aggregation_function" value="median"/> <list key="aggregation_attributes"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.007" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="aggregate" compatibility="5.3.007" expanded="true" height="76" name="Aggregate" width="90" x="112" y="165"> <parameter key="use_default_aggregation" value="true"/> <parameter key="default_aggregation_function" value="median"/> <list key="aggregation_attributes"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.3.007" expanded="true" height="76" name="Rename by Replacing" width="90" x="112" y="255"> <parameter key="replace_what" value="(.*)\(+(.*)\)+"/> <parameter key="replace_by" value="$1_$2"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.3.007" expanded="true" height="76" name="Loop Attributes" width="90" x="112" y="345"> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="5.3.007" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="%{loop_attribute}"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.3.007" expanded="true" height="94" name="enforce order" width="90" x="246" y="345"> <process expanded="true"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_attributes" compatibility="5.3.007" expanded="true" height="76" name="Loop Attributes (2)" width="90" x="380" y="345"> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="5.3.007" expanded="true" height="76" name="Generate Macro" width="90" x="112" y="30"> <list key="function_descriptions"> <parameter key="medianMacro" value=""median_"+"%{loop_attribute}""/> <parameter key="newAttributeName" value=""ratio_"+"%{loop_attribute}""/> </list> </operator> <operator activated="true" class="generate_macro" compatibility="5.3.007" expanded="true" height="76" name="Generate Macro (2)" width="90" x="112" y="120"> <list key="function_descriptions"> <parameter key="medianMacroValue" value="macro("%{medianMacro}")"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.007" expanded="true" height="76" name="Generate Attributes" width="90" x="112" y="210"> <list key="function_descriptions"> <parameter key="%{newAttributeName}" value="%{loop_attribute}/%{medianMacroValue}"/> </list> </operator> <connect from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Generate Macro (2)" to_port="through 1"/> <connect from_op="Generate Macro (2)" from_port="through 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Aggregate" from_port="original" to_op="enforce order" to_port="in 1"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="enforce order" to_port="in 2"/> <connect from_op="enforce order" from_port="out 1" to_op="Loop Attributes (2)" to_port="example set"/> <connect from_op="Loop Attributes (2)" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="696" width="706"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.008" expanded="true" height="76" name="Aggregate" width="90" x="179" y="75"> <parameter key="use_default_aggregation" value="true"/> <parameter key="default_aggregation_function" value="median"/> <list key="aggregation_attributes"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="120"> <list key="function_descriptions"> <parameter key="One" value="1"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="One" value="1"/> </list> </operator> <operator activated="true" class="join" compatibility="5.2.008" expanded="true" height="76" name="Join" width="90" x="447" y="75"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="One" value="One"/> </list> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Aggregate" from_port="original" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="180"/> </process> </operator></process>
