robert99 wrote:The default Java for Windows 8 64 bit is still 32 bit I believe (installation does not indicate which).
Nils wrote:Could you please start RapidMiner with the RapidMinerGUI.bat script in the scripts folder from a console and try to connect to the marketplace.
Retegniw wrote:You might want to go to www.java.com and use the option to have your Java version checked.
