Measures the number of times a regression prediction correctly determines the trend. This performance measure assumes that the attributes of each example represents the values of a time window, the label is a value after a certain horizon which should be predicted. All examples build a consecutive series description, i.e. the labels of all examples build the series itself (this is, for example, the case for a windowing step size of 1). This format will be delivered by the Series2ExampleSet operators provided by RapidMiner.Example: Lets think of a series v1...v10 and a sliding window with window width 3, step size 1 and prediction horizon 1. The resulting example set is thenT1 T2 T3 L P---------------v1 v2 v3 v4 p1v2 v3 v4 v5 p2v3 v4 v5 v6 p3v4 v5 v6 v7 p4v5 v6 v7 v8 p5v6 v7 v8 v9 p6v7 v8 v9 v10 p7The second last column (L) corresponds to the label, i.e. the value which should be predicted and the last column (P) corresponds to the predictions. The columns T1, T2, and T3 correspond to the regular attributes, i.e. the points which should be used as learning input.This performance measure then calculates the actuals trend between the last time point in the series (T3 here) and the actual label (L) and compares it to the trend between T3 and the prediction (P), sums the products between both trends, and divides this sum by the total number of examples, i.e. [(if ((v4-v3)*(p1-v3)>=0), 1, 0) + (if ((v5-v4)*(p2-v4)>=0), 1, 0) +...] / 7 in this example.
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="subprocess" compatibility="5.3.008" expanded="true" height="76" name="Subprocess" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="new_performance" value="1*2"/> </list> </operator> <operator activated="true" class="extract_performance" compatibility="5.3.008" expanded="true" height="76" name="Performance" width="90" x="180" y="30"> <parameter key="performance_type" value="statistics"/> <parameter key="attribute_name" value="new_performance"/> </operator> <connect from_port="in 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Subprocess" to_port="in 1"/> <connect from_op="Subprocess" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
