<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.005" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="attributes_lower_bound" value="3.0"/> <parameter key="attributes_upper_bound" value="7.0"/> </operator> <operator activated="true" class="discretize_by_bins" compatibility="5.3.005" expanded="true" height="94" name="Discretize" width="90" x="246" y="75"> <parameter key="number_of_bins" value="3"/> </operator> <operator activated="true" class="generate_data" compatibility="5.3.005" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="300"> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model" width="90" x="313" y="300"> <list key="application_parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_port="result 1"/> <connect from_op="Discretize" from_port="preprocessing model" to_op="Apply Model" to_port="model"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
