RapidMiner hanging on startup at "Loading GUI properties", MAC OSX Mountain Lion
So i've tried starting up RapidMiner on my mac, running Mountain Lion OSX, I also have the latest version of Java 7. The loading screen will appear, but then it will hang on "Loading GUI properties". This occurs when I double click on the rapidminer.jar file. I've also attempted to load it by running the file RapidMinerGUI through terminal, still to no avail, it begins loading up, and hangs on "Loading GUI properties".
Just to be more specific I ran it on Terminal by typing these instructions in, as I was not able to run the script just by cling on the file "RapidMinerGUI":
1) close Terminal if open
2) open Terminal
3) type cd and hit "return" key
4) type pwd and hit "return" key
5) verify that Terminal prints /Users/michaelrudzki
6) type cd Desktop/rapidminer/scripts/ and hit "return" key
7) type chmod a+x RapidMinerGUI and hit "return" key
8) double click on RapidMinerGUI from the Finder
Here is the Code in terminal that appears when loading it up:
Last login: Thu Mar 7 13:09:05 on ttys000
Michael-Rudzkis-MacBook-Pro:~ michaelrudzki$ /Users/michaelrudzki/Desktop/rapidminer/scripts/RapidMinerGUI ; exit;
RAPIDMINER_HOME is not set. Trying the directory '/Users/michaelrudzki/Desktop/rapidminer'...
grep: /proc/cpuinfo: No such file or directory
Number of cores: 2
Number of GC Threads: 1
No maximum Java memory defined, using 1024 Mb...
Starting RapidMiner from '/Users/michaelrudzki/Desktop/rapidminer', using classes from '/Users/michaelrudzki/Desktop/rapidminer/lib/rapidminer.jar'...
Java version: 16
Starting with CMS garbage collector
Starting in multi-core mode
Mar 7, 2013 1:10:26 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is '/Users/michaelrudzki/Desktop/rapidminer'.
Mar 7, 2013 1:10:28 PM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform ANY
Mar 7, 2013 1:10:29 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
WARNING: Unable to create user home rapidminer directory /Users/michaelrudzki/.RapidMiner5
Mar 7, 2013 1:10:29 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Mar 7, 2013 1:10:29 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Mar 7, 2013 1:10:29 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: Failed to create lock file /Users/michaelrudzki/.RapidMiner5/safeMode.lock.
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:883)
at com.rapidminer.gui.safemode.SafeMode.launchStarts(SafeMode.java:63)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:543)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.rapid_i.Launcher.main(Launcher.java:346)
Mar 7, 2013 1:10:31 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Mar 7, 2013 1:10:31 PM com.rapidminer.RapidMiner performFirstInitialization
INFO: Performing upgrade to version 5.3.005
Mar 7, 2013 1:10:31 PM com.rapidminer.RapidMiner writeLastVersion
WARNING: Cannot write current version into property file.
java.io.FileNotFoundException: /Users/michaelrudzki/.RapidMiner5/lastversion (No such file or directory)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:194)
at java.io.FileOutputStream.<init>(FileOutputStream.java:145)
at java.io.FileWriter.<init>(FileWriter.java:73)
at com.rapidminer.RapidMiner.writeLastVersion(RapidMiner.java:721)
at com.rapidminer.RapidMiner.performInitialSettings(RapidMiner.java:712)
at com.rapidminer.RapidMiner.splashMessage(RapidMiner.java:642)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:242)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:563)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:544)
Mar 7, 2013 1:10:31 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
Mar 7, 2013 1:10:32 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Mar 7, 2013 1:10:35 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Mar 7, 2013 1:10:37 PM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
Mar 7, 2013 1:10:37 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Mar 7, 2013 1:10:37 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Mar 7, 2013 1:10:37 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
Mar 7, 2013 1:10:38 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Mar 7, 2013 1:10:38 PM com.rapidminer.tools.cipher.KeyGeneratorTool createAndStoreKey
WARNING: Failed to delete old key file.
WARNING: Failed to generate key: java.io.FileNotFoundException: /Users/michaelrudzki/.RapidMiner5/cipher.key (No such file or directory)
at com.rapidminer.tools.cipher.KeyGeneratorTool.createAndStoreKey(KeyGeneratorTool.java:91)
at com.rapidminer.RapidMiner.init(RapidMiner.java:575)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:243)
Mar 7, 2013 1:10:38 PM com.rapidminer.RapidMiner init
WARNING: Cannot generate encryption key: Cannot store key: /Users/michaelrudzki/.RapidMiner5/cipher.key (No such file or directory)
com.rapidminer.tools.cipher.KeyGenerationException: Cannot store key: /Users/michaelrudzki/.RapidMiner5/cipher.key (No such file or directory)
at com.rapidminer.tools.cipher.KeyGeneratorTool.createAndStoreKey(KeyGeneratorTool.java:102)
Mar 7, 2013 1:10:39 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Mar 7, 2013 1:10:39 PM com.rapidminer.repository.RepositoryManager createRepositoryIfNoneIsDefined
WARNING: Failed to create default repository.
com.rapidminer.repository.RepositoryException: Cannot create repository folder at '/Users/michaelrudzki/.RapidMiner5/repositories/Local Repository'.
at com.rapidminer.repository.local.SimpleFolder.mkdir(SimpleFolder.java:70)
at com.rapidminer.repository.local.LocalRepository.<init>(LocalRepository.java:89)
at com.rapidminer.repository.local.LocalRepository.<init>(LocalRepository.java:82)
at com.rapidminer.repository.RepositoryManager.createRepositoryIfNoneIsDefined(RepositoryManager.java:267)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:256)
Mar 7, 2013 1:10:44 PM com.rapidminer.gui.tools.ResourceAction addToActionMap
WARNING: Cannot add action save_building_block to input map: no accelerator defined.
WARNING: Cannot add action toggle_all_breakpoints to input map: no accelerator defined.
Mar 7, 2013 1:10:45 PM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
Exception in thread "main" java.lang.reflect.InvocationTargetException
Caused by: java.lang.NullPointerException
at com.rapidminer.gui.ApplicationPerspectives.loadAll(ApplicationPerspectives.java:257)
at com.rapidminer.gui.RapidMinerGUI.loadGUIProperties(RapidMinerGUI.java:502)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:269)
... 5 more
Anyone's help would be greatly appreciated, I need this software for a school/work project. [move][/move]
