"[MOVED] Filter text from a list of word"
User: "johan_CG"
New Altair Community Member
Updated by Jocelyn
Hi everybody,
I build a process to search and count a list of keywords in thousands of files.
I built the keywords list from a Excel file after seraval operations in an example set with a keyword by example.
I would like to be able to do something like an inverse of "Filter stopwords (Dictionary)" using the attribute of my example set (or a word list if someone can explain me how to convert an example set attribute into a word list).
I found the following topics but I don't know if there is something new since: In these topics they talk about using "Filter Tokens (by Content)" operator with "matches" and the words in the regular expression but I can't use this solution because I have tens of keywords list with hundreds of keywords each. They talk also about modify the source code "Filter stopwords (Dictionary)" operator, is somebody able to tell me where I can find the source code of the operator and how to install my own operator in RapidMiner?
Thanks in advance
Johan
EDIT: I put this topic into the wrong place.
I moved it to this place http://rapid-i.com/rapidforum/index.php/topic,6340.0.html
Comments
No comments on this post.
