<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.006" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.006" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="two gaussians classification"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="read_xml" compatibility="5.3.006" expanded="true" height="60" name="Read XML" width="90" x="45" y="165"> <parameter key="file" value="/home/marcin/svn_model.xml"/> <parameter key="xpath_for_examples" value="//object-stream/com.rapidminer.operator.learner.functions.kernel.LibSVMModel/com.rapidminer.operator.learner.functions.kernel.LibSVMModel/default/model/SV/libsvm.svm__node-array"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="libsvm.svm__node[1]/value[1]/text()"/> <parameter key="xpath_for_attribute" value="libsvm.svm__node[2]/value[1]/text()"/> </enumeration> <list key="namespaces"/> <parameter key="use_default_namespace" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.real.attribute"/> <parameter key="1" value="att2.true.real.attribute"/> </list> </operator> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.3.006" expanded="true" height="76" name="SVM" width="90" x="246" y="30"> <list key="class_weights"/> </operator> <operator activated="true" class="write_model" compatibility="5.3.006" expanded="true" height="60" name="Write Model" width="90" x="447" y="30"> <parameter key="model_file" value="/home/marcin/svn_model.xml"/> <parameter key="output_type" value="XML"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="SVM" to_port="training set"/> <connect from_op="Read XML" from_port="output" to_port="result 2"/> <connect from_op="SVM" from_port="model" to_op="Write Model" to_port="input"/> <connect from_op="Write Model" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
