"Replace Missing Values Failure"
I tried the Replace Missing Values operator in the tutorial, and it didn't seem to replace any of the null values.
<process version="5.3.005">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" breakpoints="after" class="retrieve" compatibility="5.3.005" expanded="true" height="60" name="Labor-Negotiations" width="90" x="112" y="120">
<parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/>
<operator activated="true" class="replace_missing_values" compatibility="5.2.000" expanded="true" height="94" name="Replace Missing Values" width="90" x="313" y="120">
<parameter key="attribute_filter_type" value="no_missing_values"/>
<parameter key="attribute" value="duration"/>
<parameter key="attributes" value="|duration|wage-inc-1st"/>
<list key="columns">
<parameter key="wage-inc-1st" value="minimum"/>
<parameter key="wage-inc-2nd" value="maximum"/>
<parameter key="wage-inc-3rd" value="zero"/>
<parameter key="working-hours" value="value"/>
</list>
<parameter key="replenishment_value" value="35"/>
<connect from_op="Labor-Negotiations" from_port="output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="90"/>
<portSpacing port="sink_result 2" spacing="36"/>
</process>
</process>
1 - 4 of
41
Thanks Marius, that seemed to work. But now I have to figure out why my own process doesn't want to replace missing values.
Marius wrote: Marius wrote: Marius wrote:
For me, the process you have posted works perfectly. But did you notice that there is a break point after the Retrieve operator? That means that the process will stop after data loading and show an intermediate result. Note that the Run button is green while the process is in the breakpoint. To execute the next operators, you have to press the green Play button again.
Best regards,
Marius
(Also I noticed that RM requires Java 7 now? I guess this means OSX 10.6.8 is unsupported?)
Your java concerns have been answered here: http://rapid-i.com/rapidforum/index.php/topic,6254.msg22177.html#msg22177
Best regards,
Marius
