Hi guys,
in my master thesis i have to realize a consensus cluster (cc), (or cluster ensemble called). My simple example for testing is to create a cc (k-medoids and k-means) of iris...
Do not ask about the sense of this combination
Unfortunately, my search provided no response, how can I create a cc in RapidMiner 5. Simple tinkering has not brought me further. The
Group Model operator or the
Model Combiner operator do not seem to be the right thing.
My problem ist to combine the cluster outputs to an example set, so that i can put them in a classification operator. This applies to the attempt on the exsample set itself and the models from the cluster operators. Maybe I have an understanding problem? Maybe I need to make a classification for each cluster and combine these results? ???
My main strategy is the following:
- Pre-processing
- Split dataset
- Use different cluster algorithms
- Create a cc
- Create a classification model based on the cc
The images show you the strategy, which you can download her:
https://www.dropbox.com/s/857x6r5asw3m86b/strategie.png.Briefly, I considered to solve it with the R integration. But there must be a better way. I would be happy about any ideas, suggestions or comments. Thanks in advance
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<parameter key="parallelize_main_process" value="false"/>
<process expanded="true" height="431" width="748">
<operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/>
<operator activated="true" class="k_medoids" compatibility="5.2.008" expanded="true" height="76" name="k-medois" width="90" x="313" y="120">
<parameter key="add_cluster_attribute" value="true"/>
<parameter key="add_as_label" value="false"/>
<parameter key="remove_unlabeled" value="false"/>
<parameter key="k" value="2"/>
<parameter key="max_runs" value="10"/>
<parameter key="max_optimization_steps" value="100"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="measure_types" value="MixedMeasures"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="EuclideanDistance"/>
<parameter key="divergence" value="GeneralizedIDivergence"/>
<parameter key="kernel_type" value="radial"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_degree" value="3.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="k-means" width="90" x="313" y="30">
<parameter key="determine_good_start_values" value="false"/>
<parameter key="measure_types" value="BregmanDivergences"/>
<parameter key="divergence" value="SquaredEuclideanDistance"/>
<operator activated="true" class="support_vector_machine" compatibility="5.2.008" expanded="true" height="112" name="SVM" width="90" x="514" y="30">
<parameter key="kernel_type" value="dot"/>
<parameter key="kernel_degree" value="2.0"/>
<parameter key="kernel_cache" value="200"/>
<parameter key="C" value="0.0"/>
<parameter key="convergence_epsilon" value="0.0010"/>
<parameter key="max_iterations" value="100000"/>
<parameter key="scale" value="true"/>
<parameter key="calculate_weights" value="true"/>
<parameter key="return_optimization_performance" value="true"/>
<parameter key="L_pos" value="1.0"/>
<parameter key="L_neg" value="1.0"/>
<parameter key="epsilon" value="0.0"/>
<parameter key="epsilon_plus" value="0.0"/>
<parameter key="epsilon_minus" value="0.0"/>
<parameter key="balance_cost" value="false"/>
<parameter key="quadratic_loss_pos" value="false"/>
<parameter key="quadratic_loss_neg" value="false"/>
<parameter key="estimate_performance" value="false"/>
<connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="k-means" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="k-medois" to_port="example set"/>
<connect from_op="SVM" from_port="model" to_port="result 1"/>
<connect from_op="SVM" from_port="weights" to_port="result 2"/>
</process>
</process>
