<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.005" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="generate_id" compatibility="5.3.005" expanded="true" height="76" name="Generate ID" width="90" x="179" y="165"/> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.005" expanded="true" height="94" name="Forward Selection" width="90" x="313" y="165"> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation" width="90" x="112" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="5.3.005" expanded="true" height="76" name="Naive Bayes" width="90" x="45" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.005" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="optimize_selection_backward" compatibility="5.3.005" expanded="true" height="94" name="Backward Elimination" width="90" x="447" y="165"> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.005" expanded="true" height="112" name="Validation (3)" width="90" x="45" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="5.3.005" expanded="true" height="76" name="Naive Bayes (3)" width="90" x="160" y="30"/> <connect from_port="training" to_op="Naive Bayes (3)" to_port="training set"/> <connect from_op="Naive Bayes (3)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model (3)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.005" expanded="true" height="76" name="Performance (3)" width="90" x="260" y="30"/> <connect from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/> <connect from_op="Performance (3)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Validation (3)" to_port="training"/> <connect from_op="Validation (3)" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="remember" compatibility="5.3.005" expanded="true" height="60" name="Remember" width="90" x="581" y="165"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.005" expanded="true" height="94" name="Multiply" width="90" x="715" y="165"/> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.005" expanded="true" height="94" name="Forward Selection (2)" width="90" x="849" y="75"> <process expanded="true"> <operator activated="true" class="recall" compatibility="5.3.005" expanded="true" height="60" name="Recall" width="90" x="45" y="120"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="join" compatibility="5.3.005" expanded="true" height="76" name="Join" width="90" x="246" y="30"> <list key="key_attributes"/> </operator> <operator activated="true" class="x_validation" compatibility="5.3.005" expanded="true" height="112" name="Validation (2)" width="90" x="447" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="5.3.005" expanded="true" name="Naive Bayes (2)"/> <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" name="Apply Model (2)"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.005" expanded="true" name="Performance (2)"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Recall" from_port="result" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Validation (2)" to_port="training"/> <connect from_op="Validation (2)" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.005" expanded="true" height="76" name="Join (2)" width="90" x="983" y="165"> <list key="key_attributes"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Forward Selection" to_port="example set"/> <connect from_op="Forward Selection" from_port="example set" to_op="Backward Elimination" to_port="example set"/> <connect from_op="Backward Elimination" from_port="example set" to_op="Remember" to_port="store"/> <connect from_op="Remember" from_port="stored" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Forward Selection (2)" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Join (2)" to_port="right"/> <connect from_op="Forward Selection (2)" from_port="example set" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="144"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.005" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="generate_id" compatibility="5.3.005" expanded="true" height="76" name="Generate ID" width="90" x="112" y="165"/> <operator activated="true" class="multiply" compatibility="5.3.005" expanded="true" height="94" name="Multiply (2)" width="90" x="246" y="165"/> <operator activated="true" class="optimize_selection_evolutionary" compatibility="5.3.005" expanded="true" height="94" name="Optimize Selection (Evolutionary)" width="90" x="313" y="30"> <parameter key="restrict_maximum" value="true"/> <parameter key="min_number_of_attributes" value="20"/> <parameter key="max_number_of_attributes" value="40"/> <parameter key="maximum_number_of_generations" value="35"/> <parameter key="use_early_stopping" value="true"/> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation" width="90" x="112" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="5.3.005" expanded="true" height="76" name="k-NN" width="90" x="103" y="30"> <parameter key="k" value="10"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="ChebychevDistance"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.005" expanded="true" height="76" name="Performance_firstSelection" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance_firstSelection" to_port="labelled data"/> <connect from_op="Performance_firstSelection" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="remember" compatibility="5.3.005" expanded="true" height="60" name="Remember (2)" width="90" x="447" y="30"> <parameter key="name" value="weight"/> <parameter key="io_object" value="AttributeWeights"/> </operator> <operator activated="true" class="optimize_selection_backward" compatibility="5.3.005" expanded="true" height="94" name="Backward Elimination" width="90" x="447" y="165"> <parameter key="maximal_number_of_eliminations" value="30"/> <parameter key="speculative_rounds" value="10"/> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.005" expanded="true" height="112" name="Validation_BE" width="90" x="380" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="5.3.005" expanded="true" height="76" name="k-NN (2)" width="90" x="112" y="30"> <parameter key="k" value="10"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="ChebychevDistance"/> </operator> <connect from_port="training" to_op="k-NN (2)" to_port="training set"/> <connect from_op="k-NN (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model (3)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.005" expanded="true" height="76" name="Performance_after_BE" width="90" x="260" y="30"/> <connect from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance_after_BE" to_port="labelled data"/> <connect from_op="Performance_after_BE" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Validation_BE" to_port="training"/> <connect from_op="Validation_BE" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="remember" compatibility="5.3.005" expanded="true" height="60" name="Remember" width="90" x="581" y="75"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.005" expanded="true" height="76" name="Multiply" width="90" x="648" y="165"/> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.005" expanded="true" height="94" name="Forward Selection (2)" width="90" x="715" y="75"> <parameter key="maximal_number_of_attributes" value="20"/> <parameter key="speculative_rounds" value="10"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="5.3.005" expanded="true" height="60" name="Recall" width="90" x="45" y="120"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="join" compatibility="5.3.005" expanded="true" height="76" name="Join" width="90" x="246" y="30"> <list key="key_attributes"/> </operator> <operator activated="true" class="x_validation" compatibility="5.3.005" expanded="true" height="112" name="Validation_FS" width="90" x="447" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="5.3.005" expanded="true" height="76" name="k-NN (3)" width="90" x="113" y="30"> <parameter key="k" value="10"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="ChebychevDistance"/> </operator> <connect from_port="training" to_op="k-NN (3)" to_port="training set"/> <connect from_op="k-NN (3)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.005" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.005" expanded="true" height="76" name="Performance_after_FS" width="90" x="231" y="30"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance_after_FS" to_port="labelled data"/> <connect from_op="Performance_after_FS" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Recall" from_port="result" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Validation_FS" to_port="training"/> <connect from_op="Validation_FS" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.005" expanded="true" height="76" name="Join_final" width="90" x="849" y="75"> <list key="key_attributes"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Optimize Selection (Evolutionary)" to_port="example set in"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Forward Selection (2)" to_port="example set"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="example set out" to_op="Backward Elimination" to_port="example set"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="weights" to_op="Remember (2)" to_port="store"/> <connect from_op="Optimize Selection (Evolutionary)" from_port="performance" to_port="result 2"/> <connect from_op="Backward Elimination" from_port="example set" to_op="Remember" to_port="store"/> <connect from_op="Backward Elimination" from_port="performance" to_port="result 3"/> <connect from_op="Remember" from_port="stored" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Join_final" to_port="right"/> <connect from_op="Forward Selection (2)" from_port="example set" to_op="Join_final" to_port="left"/> <connect from_op="Forward Selection (2)" from_port="performance" to_port="result 4"/> <connect from_op="Join_final" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="144"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
