PCA Eigenvectors?
When I ran PCA, I got a set of eigenvectors that are different from those produced by R's prcomp() with scaling turned on. RapidMiner gave me this:
Global_active_power 0.538 -0.051 0.030 0.045 0.159 -0.426 0.706
Global_reactive_power 0.187 0.670 -0.340 -0.627 -0.026 0.078 0.013
Voltage -0.296 0.142 -0.060 0.049 0.940 -0.056 -0.010
Global_intensity 0.540 -0.032 0.019 0.042 0.141 -0.429 -0.708
Sub_metering_1 0.295 -0.100 -0.741 0.431 0.063 0.405 0.002
Sub_metering_2 0.266 0.573 0.500 0.465 0.026 0.365 0.002
Sub_metering_3 0.372 -0.434 0.283 -0.446 0.259 0.572 -0.011
But R gave me this:
PC1 PC2 PC3 PC4 PC5 PC6 PC7
Global_active_power -0.5381097 0.05112019 0.02978743 0.04476800 -0.15868069 0.42622395 -0.705752668
Global_reactive_power -0.1867954 -0.67037848 -0.34034177 -0.62679327 0.02649741 -0.07819877 -0.013441617
Voltage 0.2961116 -0.14239228 -0.05952547 0.04939298 -0.93956025 0.05646484 0.009883380
Global_intensity -0.5398184 0.03167064 0.01911187 0.04194898 -0.14069402 0.42915594 0.708165563
Sub_metering_1 -0.2953051 0.10046871 -0.74088814 0.43078174 -0.06308568 -0.40525145 -0.002067051
Sub_metering_2 -0.2660841 -0.57326777 0.50049983 0.46511374 -0.02618255 -0.36474801 -0.002411597
Sub_metering_3 -0.3720936 0.43355614 0.28276549 -0.44611987 -0.25862083 -0.57235055 0.011236558
As you can see, the eigenvectors from RapidMiner and R have the same magnitude but opposite direction. What am I missing?
Thanks,
Will
