I have the same problem :
"This process would need more than the maximum amount of available memory. You can either leave the process as it is and use a computer with more memory, reduce the amount of data by one of the sampling operators, optimize the process by using other learning or preprocessing schemes."
Is there any idea?!!
I really appreciate any help you can provide.
