<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="5.3.005" expanded="true" height="60" name="Read Excel" width="90" x="45" y="120"> <parameter key="excel_file" value="C:\temp\Links.xls"/> <parameter key="imported_cell_range" value="A1:A518"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Link.true.file_path.attribute"/> </list> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.3.000" expanded="true" height="60" name="Get Pages" width="90" x="179" y="30"> <parameter key="link_attribute" value="Link"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.3.000" expanded="true" height="60" name="Data to Documents" width="90" x="315" y="30"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.000" expanded="true" height="94" name="Process Documents" width="90" x="450" y="30"> <parameter key="prune_below_rank" value="5.0"/> <parameter key="prune_above_rank" value="5.0"/> <process expanded="true"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.3.000" expanded="true" height="60" name="Extract Content" width="90" x="179" y="75"> <parameter key="extract_content" value="false"/> </operator> <operator activated="true" class="text:extract_information" compatibility="5.3.000" expanded="true" height="60" name="Extract Information" width="90" x="447" y="30"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="ResidueDefinition" value="//h:h1[@style='text-align:left']/text()"/> <parameter key="Footnote1" value="//h:div[@class='col60']/h:ul/h:li[1]/text()"/> <parameter key="Footnote2" value="//h:div[@class='col60']/h:ul/h:li[2]/text()"/> <parameter key="LegisLink" value="//h:div[@class='col40']/h:p/h:a[1]/@href"/> <parameter key="LegisText" value="//h:div[@class='col40']/h:p/h:a[1]/text()"/> <parameter key="Footnote3" value="//h:div[@class='col60']/h:ul/h:li[3]/text()"/> <parameter key="Footnote4" value="//h:div[@class='col60']/h:ul/h:li[4]/text()"/> <parameter key="Footnote5" value="//h:div[@class='col60']/h:ul/h:li[5]/text()"/> <parameter key="Footnote6" value="//h:div[@class='col60']/h:ul/h:li[6]/text()"/> <parameter key="Footnote7" value="//h:div[@class='col60']/h:ul/h:li[7]/text()"/> <parameter key="Footnote8" value="//h:div[@class='col60']/h:ul/h:li[8]/text()"/> <parameter key="Footnote9" value="//h:div[@class='col60']/h:ul/h:li[9]/text()"/> <parameter key="Footnote10" value="//h:div[@class='col60']/h:ul/h:li[10]/text()"/> <parameter key="Footnote11" value="//h:div[@class='col60']/h:ul/h:li[11]/text()"/> <parameter key="Footnote12" value="//h:div[@class='col60']/h:ul/h:li[12]/text()"/> </list> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.005" expanded="true" height="76" name="Select Attributes" width="90" x="581" y="75"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|LegisLink|LegisText|Footnote2|Footnote1|Footnote3|Footnote4|Footnote5|Footnote6|Footnote7|Footnote8|Footnote9|Footnote10|Footnote11|Footnote12|ResidueDefinition"/> </operator> <operator activated="true" class="write_excel" compatibility="5.3.005" expanded="true" height="76" name="Write Excel" width="90" x="581" y="210"> <parameter key="excel_file" value="C:\Temp\RdEU.xlsx"/> <parameter key="file_format" value="xlsx"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Write Excel" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
RapidMiner: 5.3.005Parallel Processing: 5.3.000Text Processing: 5.3.000Weka: 5.3.001Web Mining: 5.3.000Series: 5.3.000
Stack trace:------------Exception: java.lang.NoSuchMethodErrorMessage: java.nio.CharBuffer.subSequence(II)Ljava/nio/CharBuffer;Stack trace: com.rapidminer.operator.io.web.GetWebpageOperator.read(GetWebpageOperator.java:207) com.rapidminer.operator.io.web.GetWebpageOperator.read(GetWebpageOperator.java:61) com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:126) com.rapidminer.operator.Operator.execute(Operator.java:855) com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51) com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711) com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379) com.rapidminer.operator.Operator.execute(Operator.java:855) com.rapidminer.Process.run(Process.java:949) com.rapidminer.Process.run(Process.java:873) com.rapidminer.Process.run(Process.java:832) com.rapidminer.Process.run(Process.java:827) com.rapidminer.Process.run(Process.java:817) com.rapidminer.gui.ProcessThread.run(ProcessThread.java:63)
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true"> <operator activated="true" class="web:get_webpage" compatibility="5.3.000" expanded="true" height="60" name="Get Page" width="90" x="179" y="75"> <parameter key="url" value="http://www.google.com"/> <parameter key="random_user_agent" value="true"/> <parameter key="connection_timeout" value="10000"/> <parameter key="read_timeout" value="10000"/> <parameter key="follow_redirects" value="true"/> <parameter key="accept_cookies" value="none"/> <parameter key="cookie_scope" value="global"/> <parameter key="request_method" value="GET"/> <list key="query_parameters"/> <list key="request_properties"/> <parameter key="override_encoding" value="false"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_op="Get Page" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Nils wrote:Hi,this bug occurs because you are using Java 6. Please install Java 7. Afterwards everything works fine again.Best,Nils
Nils wrote:Yes Apple does not provide a new Java version anymore. But you can use Orcales Java 7 now: http://java.com/en/download/manual.jspBest,Nils
