<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.006" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.006" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.3.006" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="30"/> <operator activated="true" class="apply_model" compatibility="5.3.006" expanded="true" height="76" name="Apply Model" width="90" x="313" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="select_recall" compatibility="5.3.006" expanded="true" height="76" name="Select Recall" width="90" x="447" y="30"/> <operator activated="true" class="apply_threshold" compatibility="5.3.006" expanded="true" height="76" name="Apply Threshold" width="90" x="581" y="30"/> <connect from_op="Retrieve Sonar" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Select Recall" to_port="example set"/> <connect from_op="Select Recall" from_port="example set" to_op="Apply Threshold" to_port="example set"/> <connect from_op="Select Recall" from_port="threshold" to_op="Apply Threshold" to_port="threshold"/> <connect from_op="Apply Threshold" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
