<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="431" width="748"> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve DvW_werkdata_DAFnaanalyse3 (2)" width="90" x="45" y="30"> <parameter key="repository_entry" value="DvW_werkdata_DAFnaanalyse3"/> </operator> <operator activated="true" class="format_numbers" compatibility="5.3.000" expanded="true" height="76" name="Format Numbers" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|DAFstatusY01|DAFstatusY02|DAFstatusY03|DAFstatusY04|DAFstatusY05|DAFstatusY06|DAFstatusY07|DAFstatusY08|DAFstatusY09|DAFstatusY10|DAFstatusY11|DAFstatusY12|DAFstatusY13|DAFstatusY14|DAFstatusY15|DAFstatusY16|DAFstatusY17|DAFstatusY18|DAFstatusY19|DAFstatusY20"/> <parameter key="format_type" value="integer"/> <parameter key="locale" value="Dutch (Belgium)"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.000" expanded="true" height="76" name="Creating churncode carriere" width="90" x="313" y="120"> <process expanded="true" height="541" width="701"> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (2)" width="90" x="45" y="30"> <parameter key="first_attribute" value="DAFstatusY01"/> <parameter key="second_attribute" value="DAFstatusY02"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation" width="90" x="179" y="30"> <parameter key="first_attribute" value="DAFstatusY03"/> <parameter key="second_attribute" value="DAFstatusY04"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (3)" width="90" x="313" y="30"> <parameter key="first_attribute" value="DAFstatusY05"/> <parameter key="second_attribute" value="DAFstatusY06"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (4)" width="90" x="447" y="30"> <parameter key="first_attribute" value="DAFstatusY07"/> <parameter key="second_attribute" value="DAFstatusY08"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (5)" width="90" x="581" y="30"> <parameter key="first_attribute" value="DAFstatusY09"/> <parameter key="second_attribute" value="DAFstatusY10"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (6)" width="90" x="45" y="120"> <parameter key="first_attribute" value="DAFstatusY11"/> <parameter key="second_attribute" value="DAFstatusY12"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (7)" width="90" x="179" y="120"> <parameter key="first_attribute" value="DAFstatusY13"/> <parameter key="second_attribute" value="DAFstatusY14"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (8)" width="90" x="313" y="120"> <parameter key="first_attribute" value="DAFstatusY15"/> <parameter key="second_attribute" value="DAFstatusY16"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (9)" width="90" x="447" y="120"> <parameter key="first_attribute" value="DAFstatusY17"/> <parameter key="second_attribute" value="DAFstatusY18"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (10)" width="90" x="581" y="120"> <parameter key="first_attribute" value="DAFstatusY19"/> <parameter key="second_attribute" value="DAFstatusY20"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (11)" width="90" x="45" y="255"> <parameter key="first_attribute" value="DAFstatusY01_DAFstatusY02"/> <parameter key="second_attribute" value="DAFstatusY03_DAFstatusY04"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (12)" width="90" x="179" y="255"> <parameter key="first_attribute" value="DAFstatusY05_DAFstatusY06"/> <parameter key="second_attribute" value="DAFstatusY07_DAFstatusY08"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (14)" width="90" x="313" y="255"> <parameter key="first_attribute" value="DAFstatusY09_DAFstatusY10"/> <parameter key="second_attribute" value="DAFstatusY11_DAFstatusY12"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (13)" width="90" x="447" y="255"> <parameter key="first_attribute" value="DAFstatusY13_DAFstatusY14"/> <parameter key="second_attribute" value="DAFstatusY15_DAFstatusY16"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (15)" width="90" x="581" y="255"> <parameter key="first_attribute" value="DAFstatusY17_DAFstatusY18"/> <parameter key="second_attribute" value="DAFstatusY19_DAFstatusY20"/> <parameter key="trim_values" value="true"/> </operator> <operator activated="true" class="rename" compatibility="5.3.000" expanded="true" height="76" name="Rename" width="90" x="45" y="345"> <parameter key="old_name" value="DAFstatusY01_DAFstatusY02_DAFstatusY03_DAFstatusY04"/> <parameter key="new_name" value="DAFChurn1"/> <list key="rename_additional_attributes"> <parameter key="DAFstatusY05_DAFstatusY06_DAFstatusY07_DAFstatusY08" value="DAFChurn2"/> <parameter key="DAFstatusY09_DAFstatusY10_DAFstatusY11_DAFstatusY12" value="DAFChurn3"/> <parameter key="DAFstatusY13_DAFstatusY14_DAFstatusY15_DAFstatusY16" value="DAFChurn4"/> <parameter key="DAFstatusY17_DAFstatusY18_DAFstatusY19_DAFstatusY20" value="DAFChurn5"/> </list> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (16)" width="90" x="179" y="345"> <parameter key="first_attribute" value="DAFChurn1"/> <parameter key="second_attribute" value="DAFChurn2"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (17)" width="90" x="313" y="345"> <parameter key="first_attribute" value="DAFChurn1_DAFChurn2"/> <parameter key="second_attribute" value="DAFChurn3"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (18)" width="90" x="447" y="345"> <parameter key="first_attribute" value="DAFChurn1_DAFChurn2_DAFChurn3"/> <parameter key="second_attribute" value="DAFChurn4"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="5.3.000" expanded="true" height="76" name="Generate Concatenation (19)" width="90" x="581" y="345"> <parameter key="first_attribute" value="DAFChurn1_DAFChurn2_DAFChurn3_DAFChurn4"/> <parameter key="second_attribute" value="DAFChurn5"/> </operator> <operator activated="true" class="rename" compatibility="5.3.000" expanded="true" height="76" name="Rename (2)" width="90" x="45" y="435"> <parameter key="old_name" value="DAFChurn1_DAFChurn2_DAFChurn3_DAFChurn4_DAFChurn5"/> <parameter key="new_name" value="DAFChurncarriere"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="179" y="435"> <list key="function_descriptions"> <parameter key="DAFChurncodecarriere" value="replace(DAFChurncarriere,"_","")"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.000" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="435"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|DAFstatusY01_DAFstatusY02|DAFstatusY03_DAFstatusY04|DAFstatusY05_DAFstatusY06|DAFstatusY07_DAFstatusY08|DAFstatusY09_DAFstatusY10|DAFstatusY11_DAFstatusY12|DAFstatusY13_DAFstatusY14|DAFstatusY15_DAFstatusY16|DAFstatusY17_DAFstatusY18|DAFstatusY19_DAFstatusY20|DAFChurn1|DAFChurn2|DAFChurn3|DAFChurn4|DAFChurn5|DAFChurn1_DAFChurn2|DAFChurn1_DAFChurn2_DAFChurn3|DAFChurn1_DAFChurn2_DAFChurn3_DAFChurn4|DAFChurn1_DAFChurn2_DAFChurn3_DAFChurn4_DAFChurn5|DAFChurncarriere"/> <parameter key="invert_selection" value="true"/> </operator> <connect from_port="in 1" to_op="Generate Concatenation (2)" to_port="example set input"/> <connect from_op="Generate Concatenation (2)" from_port="example set output" to_op="Generate Concatenation" to_port="example set input"/> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Generate Concatenation (3)" to_port="example set input"/> <connect from_op="Generate Concatenation (3)" from_port="example set output" to_op="Generate Concatenation (4)" to_port="example set input"/> <connect from_op="Generate Concatenation (4)" from_port="example set output" to_op="Generate Concatenation (5)" to_port="example set input"/> <connect from_op="Generate Concatenation (5)" from_port="example set output" to_op="Generate Concatenation (6)" to_port="example set input"/> <connect from_op="Generate Concatenation (6)" from_port="example set output" to_op="Generate Concatenation (7)" to_port="example set input"/> <connect from_op="Generate Concatenation (7)" from_port="example set output" to_op="Generate Concatenation (8)" to_port="example set input"/> <connect from_op="Generate Concatenation (8)" from_port="example set output" to_op="Generate Concatenation (9)" to_port="example set input"/> <connect from_op="Generate Concatenation (9)" from_port="example set output" to_op="Generate Concatenation (10)" to_port="example set input"/> <connect from_op="Generate Concatenation (10)" from_port="example set output" to_op="Generate Concatenation (11)" to_port="example set input"/> <connect from_op="Generate Concatenation (11)" from_port="example set output" to_op="Generate Concatenation (12)" to_port="example set input"/> <connect from_op="Generate Concatenation (12)" from_port="example set output" to_op="Generate Concatenation (14)" to_port="example set input"/> <connect from_op="Generate Concatenation (14)" from_port="example set output" to_op="Generate Concatenation (13)" to_port="example set input"/> <connect from_op="Generate Concatenation (13)" from_port="example set output" to_op="Generate Concatenation (15)" to_port="example set input"/> <connect from_op="Generate Concatenation (15)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Generate Concatenation (16)" to_port="example set input"/> <connect from_op="Generate Concatenation (16)" from_port="example set output" to_op="Generate Concatenation (17)" to_port="example set input"/> <connect from_op="Generate Concatenation (17)" from_port="example set output" to_op="Generate Concatenation (18)" to_port="example set input"/> <connect from_op="Generate Concatenation (18)" from_port="example set output" to_op="Generate Concatenation (19)" to_port="example set input"/> <connect from_op="Generate Concatenation (19)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_copy" compatibility="5.3.000" expanded="true" height="76" name="Generate Copy" width="90" x="447" y="120"> <parameter key="attribute_name" value="DAFChurncodecarriere"/> <parameter key="new_name" value="DAFChurncodecarriere2"/> </operator> <operator activated="true" class="order_attributes" compatibility="5.3.000" expanded="true" height="76" name="Reorder Attributes" width="90" x="581" y="120"> <parameter key="attribute_ordering" value="DAFChurncodecarriere|DAFChurncodecarriere2"/> </operator> <operator activated="true" class="replace" compatibility="5.3.000" expanded="true" height="76" name="Replace" width="90" x="581" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="DAFChurncodecarriere2"/> <parameter key="replace_what" value=""000001"\d[0-9]"/> <parameter key="replace_by" value=""1"\d[0-9]"/> </operator> <connect from_op="Retrieve DvW_werkdata_DAFnaanalyse3 (2)" from_port="output" to_op="Format Numbers" to_port="example set input"/> <connect from_op="Format Numbers" from_port="example set output" to_op="Creating churncode carriere" to_port="in 1"/> <connect from_op="Creating churncode carriere" from_port="out 1" to_op="Generate Copy" to_port="example set input"/> <connect from_op="Generate Copy" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_op="Replace" to_port="example set input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>[ /code]
