[SOLVED] Similarity to data: sorting and selecting rows
Ugo
New Altair Community Member
I have used a data set to generate a matrix with the similarity values (using the Similarity to Data operator).
I would like to go through each example and:
1. sort the matrix row
2. select the top k elements
So far I managed to use a "Loop Example" operator to go over each data set line, however
I cannot seem to manage to extract the whole line (all attributes for sorting). How can I do this?
The "Extract Macro" operator seems to require that I indicate a single attribute
Assuming I can get a data row I am also taking the opportunity to ask:
How do we sort and select the top k elements of a data row?
I have also looked t the "Sort" operator but that seems work on data set columns only.
TIA,
Hugo F.
TIA,
Hugo F.
Hi Hugo,
maybe the Transpose operator can help you!
Best regards,
Marius0 -
Hi Marius,
Thanks for the input. Unfortunately the "transpose" won't work. I have just realized something.
The matrix output of the "Similarity to Data" operator is _not_ in fact a matrix ??? .
The meta data I have is:
Similarity to Data (2).exampleSet (exampleSet) Meta data: Data Table Number of examples = 0 At most 1 attribute: Generated by:
ROLE NAME TYPE RANGE MISSING
id ID polynominal ⊇[efl123009c, efls001012, efls001020, efls001040....] = 0
So even if I could extract all of the line it only has one attribute.
I expected a matrix wherein the ID is as is above, but I would have all of the range values above as attributes.
So my question now is how can I actually get the data row from from the
Can anyone point out an example that uses the results of "Similarity to Data"?
Thank you,
Hugo F.
0 -
Finally took another approach.
Did not use the matrix.
For more information see:
http://rapid-i.com/rapidforum/index.php/topic,6212.msg21746.html#msg21746
Hugo F.
