"[Solved] Windowing operator returns just 0"
User: "qwertz"
New Altair Community Member
Updated by Jocelyn
Good evening,
The following process seems to be correct to me but after windowing, all examples of the label attribute are "0". Please help!!!
If you enable the set role operator it works. So it seems that is something with the combination of windowing operator and the "id" role.
Best regards
Sachs
PS: In my original file I used dates as an id but with the same result.
<process version="5.2.008">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
   <process expanded="true" height="402" width="835">
     <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
     <operator activated="true" class="rename" compatibility="5.2.008" expanded="true" height="76" name="Rename" width="90" x="179" y="30">
       <parameter key="old_name" value="label"/>
       <parameter key="new_name" value="id"/>
       <list key="rename_additional_attributes"/>
     <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="313" y="30">
       <parameter key="name" value="id"/>
     <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="30">
       <parameter key="name" value="att3"/>
     <operator activated="false" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role (3)" width="90" x="581" y="75">
     <operator activated="true" class="series:windowing" compatibility="5.2.001" expanded="true" height="76" name="Windowing" width="90" x="715" y="30">
       <parameter key="window_size" value="1"/>
       <parameter key="create_label" value="true"/>
       <parameter key="label_attribute" value="att3"/>
     <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/>
     <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/>
     <connect from_op="Set Role" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
     <connect from_op="Set Role (2)" from_port="example set output" to_op="Windowing" to_port="example set input"/>
     <connect from_op="Windowing" from_port="example set output" to_port="result 1"/>
   </process>
</process>
1 - 2 of 21
    User: "MariusHelf"
    Hi Sachs,
    please update both RapidMiner and the Series Extension to the latest version and try again. Do you still have this problem? There has been performed quite some work on the Windowing operator.
    Best regards,
    Marius
    User: "qwertz"
    OP
    That's it! I haven't seen that there is a new version so far. Lucky me, seems that my problem has been fixed just a few days before I discovered that it is there :)
    Cheers
    Sachs
