Dear rapid-Team,
I have a problem creating pdf reports in a file loop.
The loop works fine (My test: files opened in the loop and saved as new file => OK).
The pdf report works in principle BUT during the loop a report is created ONLY for the last file in the file list.
Is this a user error or a bug?
Thanks for help .. and for your great work!!
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="839" width="681">
<operator activated="true" class="loop_files" compatibility="5.3.000" expanded="true" height="60" name="Loop Files" width="90" x="179" y="30">
<parameter key="directory" value="D:\FociExp-new\LD_V013I + II\test"/>
<parameter key="filter" value=".*RTprob[.]txt"/>
<process expanded="true" height="839" width="701">
<operator activated="true" class="read_csv" compatibility="5.3.000" expanded="true" height="60" name="Read CSV (2)" width="90" x="45" y="30">
<parameter key="csv_file" value="%{file_path}"/>
<parameter key="column_separators" value="	"/>
<parameter key="use_quotes" value="false"/>
<parameter key="date_format" value="yyyy.MM.dd G 'at' HH:mm:ss z"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="locale" value="German"/>
<parameter key="encoding" value="windows-1252"/>
<parameter key="0" value="idx .true.integer.id"/>
<parameter key="1" value="Area.true.integer.attribute"/>
<parameter key="2" value="Mean.true.real.attribute"/>
<parameter key="3" value="StdDev.false.real.attribute"/>
<parameter key="4" value="Min.false.integer.attribute"/>
<parameter key="5" value="Max.false.integer.attribute"/>
<parameter key="6" value="XM.false.real.attribute"/>
<parameter key="7" value="YM.false.real.attribute"/>
<parameter key="8" value="BX.false.integer.attribute"/>
<parameter key="9" value="BY.false.integer.attribute"/>
<parameter key="10" value="Width.false.integer.attribute"/>
<parameter key="11" value="Height.false.integer.attribute"/>
<parameter key="12" value="Circ\..true.real.attribute"/>
<parameter key="13" value="IntDen.false.integer.attribute"/>
<parameter key="14" value="Median.false.integer.attribute"/>
<parameter key="15" value="RawIntDen.false.integer.attribute"/>
<parameter key="16" value="Slice.false.integer.attribute"/>
<parameter key="17" value="AR.true.real.attribute"/>
<parameter key="18" value="Round.true.real.attribute"/>
<parameter key="19" value="Solidity.false.real.attribute"/>
<parameter key="20" value="Up25Mean.true.real.attribute"/>
<parameter key="21" value="Up4Pix.true.real.attribute"/>
<parameter key="22" value="Mean-CH2.true.real.attribute"/>
<parameter key="23" value="Max-CH2.true.integer.attribute"/>
<parameter key="24" value="Median-CH2.false.integer.attribute"/>
<parameter key="25" value="Up25Mean-CH2.true.real.attribute"/>
<parameter key="26" value="Up50Mean-CH2.false.integer.attribute"/>
<parameter key="27" value="IntDen-CH2.false.integer.attribute"/>
<parameter key="28" value="Up4Pix-CH2.true.real.attribute"/>
<parameter key="29" value="Z2.true.integer.label"/>
<parameter key="30" value="Z1.true.integer.attribute"/>
<parameter key="31" value="Z22.true.integer.attribute"/>
<parameter key="32" value="Z3.true.integer.attribute"/>
<parameter key="33" value="-1-.false.integer.attribute"/>
<parameter key="34" value="p1.false.real.attribute"/>
<parameter key="35" value="p2.false.real.attribute"/>
<parameter key="36" value="p20.false.real.attribute"/>
<parameter key="37" value="p22.false.real.attribute"/>
<parameter key="38" value="p25.false.real.attribute"/>
<parameter key="39" value="-2-.false.integer.attribute"/>
<parameter key="40" value="p1*p2.false.real.attribute"/>
<parameter key="41" value="p1*p20.false.real.attribute"/>
<parameter key="42" value="p1*p22.false.real.attribute"/>
<parameter key="43" value="p1*p25.false.real.attribute"/>
<parameter key="44" value="p2*p20.false.real.attribute"/>
<parameter key="45" value="p2*p22.false.real.attribute"/>
<parameter key="46" value="p2*p25.false.real.attribute"/>
<parameter key="47" value="p20*p22.false.real.attribute"/>
<parameter key="48" value="p20*p25.false.real.attribute"/>
<parameter key="49" value="p22*p25.false.real.attribute"/>
<parameter key="50" value="p1*p2*p20.false.real.attribute"/>
<parameter key="51" value="p1*p2*p22.false.real.attribute"/>
<parameter key="52" value="p1*p2*p25.false.real.attribute"/>
<parameter key="53" value="p1*p20*p22.false.real.attribute"/>
<parameter key="54" value="p1*p20*p25.false.real.attribute"/>
<parameter key="55" value="p1*p22*p25.false.real.attribute"/>
<parameter key="56" value="p2*p20*p22.false.real.attribute"/>
<parameter key="57" value="p2*p20*p25.false.real.attribute"/>
<parameter key="58" value="p2*p22*p25.false.real.attribute"/>
<parameter key="59" value="p20*p22*p25.false.real.attribute"/>
</list>
<operator activated="true" class="provide_macro_as_log_value" compatibility="5.3.000" expanded="true" height="60" name="Provide Macro as Log Value" width="90" x="179" y="165">
<parameter key="macro_name" value="file_name"/>
<operator activated="true" class="log" compatibility="5.3.000" expanded="true" height="60" name="Log (2)" width="90" x="380" y="165">
<list key="log">
<parameter key="filename" value="operator.Provide Macro as Log Value.value.macro_value"/>
</list>
<operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="246" y="30">
<parameter key="report_name" value="Trep"/>
<parameter key="pdf_output_file" value="%{file_path}.pdf"/>
<parameter key="pdf_template_file" value="D:\Program Files\Rapid-I\RapidMiner5\no file selected"/>
<parameter key="image_template_file" value="D:\Program Files\Rapid-I\RapidMiner5\no file selected"/>
<parameter key="section_one_font" value="courier"/>
<parameter key="section_two_font" value="courier"/>
<parameter key="section_three_font" value="courier"/>
<parameter key="section_four_font" value="courier"/>
<parameter key="section_five_font" value="courier"/>
<parameter key="text_content_font" value="courier"/>
<operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="447" y="30">
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="Data Table"/>
<parameter key="renderer_name" value="Plot View"/>
<list key="parameters">
<parameter key="plotter" value="Scatter"/>
<parameter key="scatter_axis_x_axis" value="Up25Mean"/>
<parameter key="scatter_axis_x_axis_log_scale" value="false"/>
<parameter key="scatter_axis_y_axis" value="Up25Mean-CH2"/>
<parameter key="scatter_axis_y_axis_log_scale" value="false"/>
<parameter key="scatter_plot_column" value="Z22"/>
<parameter key="scatter_jitter_amount" value="0"/>
<parameter key="scatter_rotate_labels" value="false"/>
<parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/>
<parameter key="scatter_multiple_jitter_amount" value="0"/>
<parameter key="scatter_multiple_rotate_labels" value="false"/>
<parameter key="scatter_matrix_jitter_amount" value="0"/>
<parameter key="bubble_axis_x_axis_log_scale" value="false"/>
<parameter key="bubble_axis_y_axis_log_scale" value="false"/>
<parameter key="bubble_rotate_labels" value="false"/>
<parameter key="parallel_rotate_labels" value="false"/>
<parameter key="parallel_local_normalization" value="false"/>
<parameter key="deviation_rotate_labels" value="false"/>
<parameter key="deviation_local_normalization" value="false"/>
<parameter key="series_rotate_labels" value="false"/>
<parameter key="series_multiple_rotate_labels" value="false"/>
<parameter key="som_jitter_amount" value="0"/>
<parameter key="block_axis_x_axis_log_scale" value="false"/>
<parameter key="block_axis_y_axis_log_scale" value="false"/>
<parameter key="block_jitter_amount" value="0"/>
<parameter key="block_rotate_labels" value="false"/>
<parameter key="pie_absolute_values" value="false"/>
<parameter key="pie_aggregation" value="none"/>
<parameter key="pie_use_distinct" value="false"/>
<parameter key="pie_explosion_amount" value="0"/>
<parameter key="pie_3d_absolute_values" value="false"/>
<parameter key="pie_3d_aggregation" value="none"/>
<parameter key="pie_3d_use_distinct" value="false"/>
<parameter key="ring_absolute_values" value="false"/>
<parameter key="ring_aggregation" value="none"/>
<parameter key="ring_use_distinct" value="false"/>
<parameter key="ring_explosion_amount" value="0"/>
<parameter key="bars_absolute_values" value="false"/>
<parameter key="bars_rotate_labels" value="false"/>
<parameter key="bars_aggregation" value="none"/>
<parameter key="bars_use_distinct" value="false"/>
<parameter key="bars_orientation" value="vertical"/>
<parameter key="bars_stacked_absolute_values" value="false"/>
<parameter key="bars_stacked_rotate_labels" value="false"/>
<parameter key="bars_stacked_aggregation" value="none"/>
<parameter key="bars_stacked_use_distinct" value="false"/>
<parameter key="bars_stacked_orientation" value="vertical"/>
<parameter key="pareto_rotate_labels" value="false"/>
<parameter key="pareto_sorting_direction" value="Descending Keys"/>
<parameter key="pareto_show_bar_labels" value="true"/>
<parameter key="pareto_show_cumulative_labels" value="false"/>
<parameter key="distribution_rotate_labels" value="false"/>
<parameter key="histogram_absolute_values" value="false"/>
<parameter key="histogram_rotate_labels" value="false"/>
<parameter key="histogram_log_scale" value="false"/>
<parameter key="histogram_number_of_bins" value="40"/>
<parameter key="histogram_opaqueness" value="100"/>
<parameter key="histogram_color_absolute_values" value="false"/>
<parameter key="histogram_color_rotate_labels" value="false"/>
<parameter key="histogram_color_log_scale" value="false"/>
<parameter key="histogram_color_number_of_bins" value="40"/>
<parameter key="histogram_color_opaqueness" value="100"/>
</list>
<parameter key="image_height" value="810"/>
<connect from_op="Read CSV (2)" from_port="output" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/>
<portSpacing port="source_file object" spacing="0"/>
</process>
<operator activated="true" class="log_to_data" compatibility="5.3.000" expanded="true" height="76" name="Log to Data" width="90" x="380" y="30"/>
<connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/>
</process>
</process>
