[SOLVED] Keep all parameter of Generate Attributes operator with attribute overw
New Altair Community Member
Updated by Jocelyn
Isn't keep_all meant to specify whether or not to keep those attributes that are not generated within the Generate Attributes operator?
However, the following process (for example) produces an empty exampleset where I would have expected attribute a to survive.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Is this the intended behavior?
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="654" width="980">
<operator activated="true" class="generate_data_user_specification" compatibility="5.3.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="75">
<list key="attribute_values">
<parameter key="a" value="1"/>
<parameter key="b" value="2"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="75">
<parameter key="a" value="a"/>
</list>
<parameter key="keep_all" value="false"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
