<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="459" width="694"> <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="split_validation" compatibility="5.2.008" expanded="true" height="130" name="Validation" width="90" x="179" y="30"> <process expanded="true" height="459" width="165"> <operator activated="true" class="support_vector_machine_linear" compatibility="5.2.008" expanded="true" height="76" name="SVM (Linear)" width="90" x="45" y="30"/> <connect from_port="training" to_op="SVM (Linear)" to_port="training set"/> <connect from_op="SVM (Linear)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="459" width="624"> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply" width="90" x="179" y="120"/> <operator activated="true" class="performance_regression" compatibility="5.2.008" expanded="true" height="76" name="Performance (2)" width="90" x="313" y="255"> <parameter key="root_mean_squared_error" value="false"/> <parameter key="relative_error" value="true"/> </operator> <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log" width="90" x="447" y="165"> <parameter key="filename" value="log"/> <list key="log"> <parameter key="log" value="operator.Performance (2).value.relative_error"/> </list> </operator> <operator activated="true" class="performance" compatibility="5.2.008" expanded="true" height="76" name="Performance" width="90" x="313" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Performance" to_port="labelled data"/> <connect from_op="Multiply" from_port="output 2" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="averagable 2"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="403" width="701"> <operator activated="true" class="subprocess" compatibility="5.2.008" expanded="true" height="76" name="Generate Data (2)" width="90" x="45" y="30"> <process expanded="true" height="403" width="694"> <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> <parameter key="number_of_attributes" value="3"/> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="rename" compatibility="5.2.008" expanded="true" height="76" name="Rename" width="90" x="179" y="30"> <parameter key="old_name" value="att3"/> <parameter key="new_name" value="prediction"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="name" value="prediction"/> <parameter key="target_role" value="prediction"/> <list key="set_additional_roles"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="aggregate" compatibility="5.2.008" expanded="true" height="76" name="Aggregate" width="90" x="179" y="30"> <list key="aggregation_attributes"> <parameter key="label" value="average"/> <parameter key="prediction" value="average"/> </list> </operator> <operator activated="true" class="rename" compatibility="5.2.008" expanded="true" height="76" name="Rename (2)" width="90" x="313" y="30"> <parameter key="old_name" value="average(label)"/> <parameter key="new_name" value="avg_label"/> <list key="rename_additional_attributes"> <parameter key="average(prediction)" value="avg_prediction"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="447" y="30"> <list key="function_descriptions"> <parameter key="performance_att" value="avg_prediction-avg_label"/> </list> </operator> <operator activated="true" class="extract_performance" compatibility="5.2.008" expanded="true" height="76" name="Performance" width="90" x="581" y="30"> <parameter key="performance_type" value="data_value"/> <parameter key="attribute_name" value="performance_att"/> <parameter key="example_index" value="1"/> </operator> <connect from_op="Generate Data (2)" from_port="out 1" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="459" width="694"> <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="series:sliding_window_validation" compatibility="5.2.001" expanded="true" height="130" name="Validation" width="90" x="179" y="30"> <parameter key="training_window_width" value="10"/> <parameter key="test_window_width" value="10"/> <process expanded="true" height="432" width="335"> <operator activated="true" class="support_vector_machine_linear" compatibility="5.2.008" expanded="true" height="76" name="SVM (Linear)" width="90" x="45" y="30"/> <connect from_port="training" to_op="SVM (Linear)" to_port="training set"/> <connect from_op="SVM (Linear)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="432" width="500"> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="series:forecasting_performance" compatibility="5.2.001" expanded="true" height="76" name="Performance" width="90" x="179" y="75"> <parameter key="horizon" value="1"/> <parameter key="main_criterion" value="prediction_trend_accuracy"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.2.008" expanded="true" height="76" name="Performance (2)" width="90" x="313" y="120"> <parameter key="root_mean_squared_error" value="false"/> <parameter key="relative_error" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 2"/> <connect from_op="Performance" from_port="example set" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log" width="90" x="313" y="75"> <list key="log"> <parameter key="performance_a" value="operator.Validation.value.performance"/> <parameter key="performance_b" value="operator.Validation.value.performance1"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="459" width="694"> <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="series:sliding_window_validation" compatibility="5.2.001" expanded="true" height="112" name="Validation" width="90" x="179" y="30"> <parameter key="training_window_width" value="10"/> <parameter key="test_window_width" value="10"/> <process expanded="true" height="432" width="335"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.2.008" expanded="true" height="76" name="SVM" width="90" x="45" y="30"> <parameter key="svm_type" value="epsilon-SVR"/> <parameter key="kernel_type" value="linear"/> <list key="class_weights"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="432" width="480"> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="series:forecasting_performance" compatibility="5.2.001" expanded="true" height="76" name="Performance" width="90" x="179" y="30"> <parameter key="horizon" value="1"/> <parameter key="main_criterion" value="prediction_trend_accuracy"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.2.008" expanded="true" height="76" name="Performance (2)" width="90" x="313" y="30"> <parameter key="root_mean_squared_error" value="false"/> <parameter key="relative_error" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_op="Performance (2)" to_port="performance"/> <connect from_op="Performance" from_port="example set" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log" width="90" x="313" y="30"> <list key="log"> <parameter key="per" value="operator.Validation.value.performance"/> <parameter key="per2" value="operator.Validation.value.performance2"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
