Hi. While using cleanup tool, by default the element edge gets collapsed to any one node of the edge if the elements are failing minimum length or aspect ratio.
Query:
Is there a way I can change this setting so that the element edge collapses to midpoint? I can do it manually (using collapse to midpoint option) but if I can change the setting in cleanup operation it would have been so helpful.
Thanks
