Hi. I have had no luck getting the Intelligent Discovery Assistant 5.1 to run under RM 5.2 and now 5.3 using Windows XP (32). It always hangs when "Testing Flora2" -- this happens with both the basic installation and also when I tell it to look directly at the files that were installed from the previous attempt. Here is how far it gets:
http://grab.by/jgJY ; The progress bar freezes and javaw shows 0% CPU and 966xxx used, if the 1GB memory threshold is somehow relevant. This looks like a useful tool and since it is promoted in the store I figure it should run. Thanks in advance for any workarounds. Chris
