I am a just starting to use rapid miner and have a question. I found a recommender pack in the myExperiment [1] site that has data files with the extensions *.ioo and *.md. I assume these are binary files so I used rapid miner's binary data import option (File menu) to load these. However this does not seem to work. After loading and running no output data is visible. How should I load these files in the GUI?
Apologies if this is has been asked before but I only found one reference [2] that did not help me much.
TIA,
Hugo
1.
http://www.myexperiment.org/packs/179.html2.
http://rapid-i.com/rapidforum/index.php/topic,2247.msg8831.html#msg8831
