I must be missing something obvious, but why, in the following process, does one Split work and the other not?
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="654" width="970">
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30">
<list key="attribute_values">
<parameter key="line" value=""a,b""/>
</list>
<operator activated="true" class="write_csv" compatibility="5.2.008" expanded="true" height="76" name="Write CSV" width="90" x="179" y="120">
<parameter key="write_attribute_names" value="false"/>
<parameter key="quote_nominal_values" value="false"/>
<parameter key="format_date_attributes" value="false"/>
<operator activated="true" class="read_csv" compatibility="5.2.008" expanded="true" height="60" name="Read CSV" width="90" x="380" y="165">
<parameter key="use_quotes" value="false"/>
<parameter key="parse_numbers" value="false"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="0" value="line.true.nominal.regular"/>
</list>
<operator activated="true" class="split" compatibility="5.2.008" expanded="true" height="76" name="Split (2)" width="90" x="514" y="165">
<parameter key="attribute" value="line"/>
<operator activated="true" class="split" compatibility="5.2.008" expanded="true" height="76" name="Split" width="90" x="380" y="30">
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Write CSV" to_port="input"/>
<connect from_op="Write CSV" from_port="through" to_op="Split" to_port="example set input"/>
<connect from_op="Write CSV" from_port="file" to_op="Read CSV" to_port="file"/>
<connect from_op="Read CSV" from_port="output" to_op="Split (2)" to_port="example set input"/>
<connect from_op="Split (2)" from_port="example set output" to_port="result 2"/>
<connect from_op="Split" from_port="example set output" to_port="result 1"/>
</process>
</process>
