<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="190" width="346"> <operator activated="true" class="read_excel" compatibility="5.2.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.008" expanded="true" height="60" name="Loop Attributes" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="attributePRODUCTname"/> <parameter key="iteration_macro" value="product"/> <process expanded="true" height="504" width="777"> <operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="45" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="attributePRODUCTname=%{product}"/> </operator> <operator activated="true" class="x_validation" compatibility="5.0.000" expanded="true" height="112" name="Validation" width="90" x="246" y="30"> <description>A cross validation including a linear regression.</description> <process expanded="true" height="654" width="466"> <operator activated="true" class="linear_regression" compatibility="5.0.000" expanded="true" height="94" name="Linear Regression" width="90" x="45" y="30"/> <connect from_port="training" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="654" width="466"> <operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.000" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="store" compatibility="5.2.008" expanded="true" height="60" name="Store (2)" width="90" x="447" y="30"> <parameter key="repository_entry" value="//default/%{product}model"/> </operator> <operator activated="true" class="store" compatibility="5.2.008" expanded="true" height="60" name="Store" width="90" x="447" y="120"> <parameter key="repository_entry" value="//default/%{product}performance"/> </operator> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Store (2)" to_port="input"/> <connect from_op="Validation" from_port="averagable 1" to_op="Store" to_port="input"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
