There is a minor glitch on Series Multiple that kind of drive me nuts. In this case I am trying to visualize the prediction time series on top of the real values, so on results tab I select "Plot View", then Series Multiple Plotter and check the two series I want to plot.
Once plotted I want to align both axes, so I click with right button on the chart and select Auto Range > Both Axes and this is the result:
As you can see, the Y axis is not aligned. Every time I try to visualize two series I have a hard time in order to get these axes aligned. I'd like to know if I am missing something here, or if it is a common problem
Cheers,
Victor
