[SOLVED] RapidAnalytics Web Service Authentication problem
New Altair Community Member
Updated by Jocelyn
Hi There,
I am following Simon's video tutorial "RapidAnalytics 9: File Objects and POSTing to Web Services". I've uploaded my process into RapidAnalytics repository and exposed it as a webservice. Up to here I'm able to run the process through the scheduler and through service Test option.
The problem appears when I try to execute the webservice outside RapidAnalytics web interface. Calling this WS with cURL shows that the server is redirecting to the Login Page:
Best,
Victor
HTTP/1.1 100 ContinueI have triple checked and certainly I am entering my correct HTTP Basic Auth credentials. I also checked the server logs and found nothing regarding this, so I am stuck here.
HTTP/1.1 302 Moved Temporarily
Server: Apache-Coyote/1.1
X-Powered-By: Servlet/3.0; JBossAS-6
Set-Cookie: JSESSIONID=1E386EF633860836EB47164225D9CB88; Path=/RA
Location: http://myserver:8080/RA/faces/login.xhtml;jsessionid=1E386EF633860836EB47164225D9CB88
Content-Length: 0
Date: Mon, 07 Jan 2013 13:30:20 GMT
Best,
Victor
1 - 1 of
11
the URL is http://host:port/RAWS/processes/serviceID so I was calling a bad endpoint
Now it works like a charm
Cheers,
victor
