<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="549" width="567"> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="split_data" compatibility="5.3.000" expanded="true" height="94" name="Split Data" width="90" x="179" y="120"> <enumeration key="partitions"> <parameter key="ratio" value="0.7"/> <parameter key="ratio" value="0.3"/> </enumeration> </operator> <operator activated="true" class="decision_tree" compatibility="5.3.000" expanded="true" height="76" name="Decision Tree" width="90" x="313" y="30"/> <operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="447" y="120"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Decision Tree" to_port="training set"/> <connect from_op="Split Data" from_port="partition 2" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Decision Tree" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="549" width="681"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="discretize_by_bins" compatibility="5.2.008" expanded="true" height="94" name="Discretize" width="90" x="246" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="attribute_1"/> <parameter key="number_of_bins" value="10"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
