Let's say I have an example set with a label attribute (initially blank) and some reals...maybe:
| Row | Label | Att1 | Att2 | Att3 |
| 1 | | 1.3 | 1.1 | 1.2 |
| 2 | | 2.0 | 2.1 | 2.2 |
| 3 | | 3.0 | 3.2 | 3.1 |
Now for each row, I want to set the Label to be the name of the attribute where the maximal real value occurs, which for the current example would yield:
| 1 | Att1 | 1.3 | 1.1 | 1.2 |
| 2 | Att3 | 2.0 | 2.1 | 2.2 |
| 3 | Att2 | 3.0 | 3.2 | 3.1 |
I have implemented this by aggregating the max of the reals into a new attribute called Max, then looping over attributes, then looping over examples, and seeing if the value is equal to the value stored in Max, and if so using Set Data to store the attribute name in Label.
That works, but I've got O(100) reals and O(1,000) examples, so you can imagine how SSSSSLLLLLLOOOOOOOWWWWWWW it is. Ssssooooo....
The question is, is there a better and faster way to do this?
Any ideas/help would be most appreciated!
John
