Not sure if this is an installation issue or not. I did search the documentation for this and was not able to track anything related to it. I installed rapiminer 5.2 on ubuntu 12.04 and get the follwoing messages when I start Rapidminer....
Caused by: java.io.IOException: Got Connection refused while opening stream from
http://recommender.rapid-i.com:80/OperatorRecommenderService/RecommenderService?wsdl at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(RuntimeWSDLParser.java:842)
at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(RuntimeWSDLParser.java:283)
at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:140)
... 10 more
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:391)
at java.net.Socket.connect(Socket.java:579)
at java.net.Socket.connect(Socket.java:528)
at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:378)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:473)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:203)
at sun.net.www.http.HttpClient.New(HttpClient.java:290)
at sun.net.www.http.HttpClient.New(HttpClient.java:306)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:995)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:931)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:849)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1299)
at java.net.URL.openStream(URL.java:1037)
at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(RuntimeWSDLParser.java:827)
