<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="386" width="711"> <operator activated="true" class="retrieve" compatibility="5.1.011" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="SVM_Train_F_words_unigram_tf"/> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.002" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="179" y="75"> <list key="text_directories"> <parameter key="R" value="E:\R_Validation"/> <parameter key="NR" value="E:\NR_Validation"/> </list> <parameter key="extract_text_only" value="false"/> <parameter key="vector_creation" value="Term Frequency"/> <parameter key="prune_below_absolute" value="5"/> <parameter key="prune_above_absolute" value="5000000"/> <parameter key="parallelize_vector_creation" value="true"/> <process expanded="true" height="362" width="674"> <operator activated="true" class="text:tokenize" compatibility="5.1.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.002" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="315" y="73"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="retrieve" compatibility="5.1.011" expanded="true" height="60" name="Retrieve (2)" width="90" x="179" y="300"> <parameter key="repository_entry" value="SVM_Train_F_model_unigram_tf"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.011" expanded="true" height="76" name="Apply Model" width="90" x="313" y="300"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.1.011" expanded="true" height="76" name="Performance" width="90" x="447" y="75"> <list key="class_weights"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="210"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|confidence(non_res)|confidence(res)|label|prediction(label)"/> </operator> <operator activated="true" class="write_csv" compatibility="5.1.011" expanded="true" height="60" name="Write CSV" width="90" x="581" y="165"> <parameter key="csv_file" value="E:\Project\svmscore.csv"/> <parameter key="column_separator" value=","/> <parameter key="quote_nominal_values" value="false"/> <parameter key="format_date_attributes" value="false"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Process Documents from Files (2)" to_port="word list"/> <connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 2"/> <connect from_op="Performance" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
huaiyanggongzi wrote:By the way, do you know how to output the distance between a given test data point and the hyperplane constructed by training data set? I am also referring to the LiBSVM operator in Rapidminer.
