Select Attribute based on SUM
Hi ,
I have a dataset with binary (numerical : 0/1) features and I want to choose all those features which sum of their values are less than a specific value (e.g. 1000) ,
I'd be thankful if you could help me ,
Thanks ,
Arian
Thanks ,
Arian
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="611" width="949">
<operator activated="true" class="generate_massive_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Massive Data" width="90" x="45" y="120">
<parameter key="number_examples" value="100"/>
<parameter key="number_attributes" value="100"/>
<parameter key="sparse_fraction" value="0.7"/>
</process>
</process>
Comments
No comments on this post.
