[SOLVED] RapidAnalytics bug - Loop Repository operator
StaryVena
New Altair Community Member
I think I found bug in Loop repository problem. I have ExampleSets in the folder in the remote repository on the RapidAnalytics server. When I run process locally, i works fine, but when I run it remotely on server I have this error:
Václav
Process code:
Dec 18, 2012 1:23:00 PM <unknown> <unknown>
INFO: Process context is: Macros: [_ra_user : vaclav, _ra_jobID : 8]; Input: []; Output: []
INFO: No filename given for result file, using stdout for logging results!
INFO: Process //_LOCAL/home/vaclav/test starts
SEVERE: Process failed: java.lang.NullPointerException
at com.rapidminer.operator.meta.RepositoryIterator.iterate(RepositoryIterator.java:89)
at com.rapidminer.operator.meta.RepositoryIterator.iterate(RepositoryIterator.java:76)
at com.rapidminer.operator.meta.AbstractRepositoryIterator.doWork(AbstractRepositoryIterator.java:135)
at com.rapidminer.operator.meta.RepositoryIterator.doWork(RepositoryIterator.java:125)
at com.rapidminer.operator.Operator.execute(Operator.java:834)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379)
at com.rapidminer.Process.run(Process.java:925)
at com.rapidminer.Process.run(Process.java:848)
at com.rapidminer.Process.run(Process.java:807)
at com.rapidminer.Process.run(Process.java:802)
at de.rapidanalytics.execution.AbstractProcessExecutor.runProcessNow(Unknown Source)
at de.rapidanalytics.execution.SimpleProcessExecutor.execute(Unknown Source)
at de.rapidanalytics.execution.ProcessExecutionDispatcher.dispatch(Unknown Source)
at de.rapidanalytics.ejb.ProcessJobEJBImpl.executeJob(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
at org.jboss.ejb3.interceptors.container.ContainerMethodInvocationWrapper.invokeNext(ContainerMethodInvocationWrapper.java:72)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:76)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:62)
at sun.reflect.GeneratedMethodAccessor408.invoke(Unknown Source)
at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:74)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_592411083.invoke(InvocationContextInterceptor_z_fillMethod_592411083.java)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:90)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_592411083.invoke(InvocationContextInterceptor_z_setup_592411083.java)
at org.jboss.ejb3.async.impl.interceptor.AsynchronousServerInterceptor.invoke(AsynchronousServerInterceptor.java:128)
at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
at org.jboss.ejb3.tx.StatelessBMTInterceptor.handleInvocation(StatelessBMTInterceptor.java:106)
at org.jboss.ejb3.tx.BMTInterceptor.invoke(BMTInterceptor.java:55)
at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
at org.jboss.ejb3.core.context.SessionInvocationContextAdapter.proceed(SessionInvocationContextAdapter.java:95)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:247)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.required(CMTTxInterceptor.java:349)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invoke(CMTTxInterceptor.java:209)
at org.jboss.ejb3.tx2.aop.CMTTxInterceptorWrapper.invoke(CMTTxInterceptorWrapper.java:52)
at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:182)
at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
at org.jboss.ejb3.core.context.CurrentInvocationContextInterceptor.invoke(CurrentInvocationContextInterceptor.java:47)
at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
at org.jboss.ejb3.interceptor.EJB3TCCLInterceptor.invoke(EJB3TCCLInterceptor.java:86)
at org.jboss.ejb3.stateless.StatelessContainer.dynamicInvoke(StatelessContainer.java:392)
at org.jboss.ejb3.remoting.IsLocalInterceptor.invokeLocal(IsLocalInterceptor.java:88)
at org.jboss.ejb3.remoting.IsLocalInterceptor.invoke(IsLocalInterceptor.java:75)
at org.jboss.ejb3.async.impl.interceptor.AsynchronousClientInterceptor.invoke(AsynchronousClientInterceptor.java:143)
at org.jboss.aspects.remoting.PojiProxy.invoke(PojiProxy.java:62)
at $Proxy215.invoke(Unknown Source)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:185)
at $Proxy214.executeJob(Unknown Source)
at de.rapidanalytics.web.tools.ProcessExecutionJob.execute(Unknown Source)
at org.quartz.core.JobRunShell.run(JobRunShell.java:216)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:549)
SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
==> +- Loop Repository[1] (Loop Repository)
subprocess 'Nested Process'
+- Normalize[0] (Normalize)
Best wishes,
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="740" width="846">
<operator activated="true" class="loop_repository" compatibility="5.3.000" expanded="true" height="76" name="Loop Repository" width="90" x="246" y="30">
<parameter key="repository_folder" value="3DBrainSRMES24/"/>
<parameter key="entry_type" value="IOObject"/>
<parameter key="recursive" value="false"/>
<operator activated="true" class="normalize" compatibility="5.3.000" expanded="true" height="94" name="Normalize" width="90" x="246" y="30"/>
<connect from_port="repository object" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_repository object" spacing="0"/>
</process>
<connect from_op="Loop Repository" from_port="out 1" to_port="result 1"/>
</process>
</process>
Václav
Hi Václav,
thanks for the hint. I've fixed it!
Best,
Nils0
