<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <parameter key="logfile" value="/Users/wardloving/Documents/Data Mining/log.out"/> <parameter key="resultfile" value="/Users/wardloving/Documents/Data Mining/results.out"/> <process expanded="true" height="116" width="614"> <operator activated="true" class="read_database" compatibility="5.2.008" expanded="true" height="60" name="Read Database" width="90" x="45" y="30"> <parameter key="connection" value="Local MySQL Nutch"/> <parameter key="query" value="SELECT content FROM webpage where Id = 'org.episcopalchurch.www:http/parish/all-saints-episcopal-church-vista-ca'"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.008" expanded="true" height="76" name="Nominal to Text" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="content"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Data" width="90" x="514" y="30"> <parameter key="create_word_vector" value="false"/> <list key="specify_weights"/> <process expanded="true" height="252" width="1095"> <operator activated="true" class="text:extract_information" compatibility="5.2.004" expanded="true" height="60" name="Extract Information" width="90" x="112" y="75"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="Name" value="substring-before(//title, ',')"/> <parameter key="Staff Name" value="substring-before(//*[@class = 'field field-type-text field-field-clergy']/div/div/node()[not(self::div)],',')"/> <parameter key="Staff Title" value="substring-after(//*[@class = 'field field-type-text field-field-clergy']/div/div/node()[not(self::div)], ',')"/> <parameter key="Address Line 1" value="//*[@class = 'street-address']"/> <parameter key="City" value="//*[@class = 'locality']"/> <parameter key="State" value="//*[@class = 'region']"/> <parameter key="Zip" value="//*[@class = 'postal-code']"/> <parameter key="Email" value="//*[@class = 'field field-type-text field-field-email']/div/div/node()[not(self::div)]"/> <parameter key="Phone" value="//*[@class = 'field field-type-text field-field-phone']/div/div/node()[not(self::div)]"/> <parameter key="Fax" value="//*[@class = 'field field-type-text field-field-fax']/div/div/node()[not(self::div)]"/> <parameter key="URL" value="//*[@class = 'field field-type-text field-field-fax']/div/div/node()[not(self::div)]"/> <parameter key="Twitter" value="//*[@class = 'field field-type-text field-field-twitter']/div/div/node()[not(self::div)]"/> </list> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="document" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="36"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Read Database" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
