<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Root"> <process expanded="true" height="431" width="748"> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.3.000" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="179" y="30"> <list key="parameters"> <parameter key="Learner.minimal_gain" value="[0.1;20;100;linear]"/> </list> <process expanded="true" height="521" width="748"> <operator activated="true" class="x_validation" compatibility="5.3.000" expanded="true" height="112" name="X-Validation" width="90" x="45" y="30"> <parameter key="sampling_type" value="shuffled sampling"/> <process expanded="true" height="398" width="327"> <operator activated="true" class="decision_tree" compatibility="5.3.000" expanded="true" height="76" name="Learner" width="90" x="112" y="30"> <parameter key="minimal_gain" value="20.0"/> </operator> <connect from_port="training" to_op="Learner" to_port="training set"/> <connect from_op="Learner" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="398" width="327"> <operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.000" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="performance_to_data" compatibility="5.3.000" expanded="true" height="76" name="Performance to Data" width="90" x="179" y="75"/> <operator activated="true" class="extract_log_value" compatibility="5.3.000" expanded="true" height="60" name="Extract Log Value" width="90" x="313" y="30"> <parameter key="attribute_name" value="Value"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="log" compatibility="5.3.000" expanded="true" height="76" name="Log" width="90" x="447" y="120"> <list key="log"> <parameter key="minimal_gain" value="operator.Learner.parameter.minimal_gain"/> <parameter key="accuracy" value="operator.Extract Log Value.value.data_value"/> </list> </operator> <connect from_port="input 1" to_op="X-Validation" to_port="training"/> <connect from_op="X-Validation" from_port="averagable 1" to_op="Performance to Data" to_port="performance vector"/> <connect from_op="Performance to Data" from_port="example set" to_op="Extract Log Value" to_port="example set"/> <connect from_op="Performance to Data" from_port="performance vector" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="36"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="set_parameters" compatibility="5.3.000" expanded="true" height="76" name="Set Parameters" width="90" x="313" y="75"> <list key="name_map"> <parameter key="Learner" value="OptimalLearner"/> </list> </operator> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve Iris (2)" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="decision_tree" compatibility="5.3.000" expanded="true" height="76" name="OptimalLearner" width="90" x="179" y="210"/> <connect from_op="Retrieve Iris" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_op="Set Parameters" to_port="parameter set"/> <connect from_op="Set Parameters" from_port="parameter set" to_port="result 1"/> <connect from_op="Retrieve Iris (2)" from_port="output" to_op="OptimalLearner" to_port="training set"/> <connect from_op="OptimalLearner" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
