In this process, the Replace Missing Values operator affects even the output that never passed through it, if its "create view" parameter is unchecked. Is this the intended (and even default) behavior?
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="654" width="1015">
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="179" y="30">
<list key="attribute_values">
<parameter key="a" value="1"/>
<parameter key="b" value="2"/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="179" y="120">
<parameter key="z" value=""hi""/>
<parameter key="x" value="1"/>
</list>
<operator activated="true" class="union" compatibility="5.2.008" expanded="true" height="76" name="Union" width="90" x="380" y="30"/>
<operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="648" y="30">
<parameter key="c" value="a+b"/>
</list>
<operator activated="true" class="replace_missing_values" compatibility="5.2.008" expanded="true" height="94" name="Replace Missing Values" width="90" x="648" y="120">
<parameter key="attribute_filter_type" value="value_type"/>
<parameter key="value_type" value="nominal"/>
<parameter key="default" value="value"/>
<list key="columns"/>
<parameter key="replenishment_value" value="???MISSING???"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Union" to_port="example set 1"/>
<connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Union" to_port="example set 2"/>
<connect from_op="Union" from_port="union" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
<connect from_op="Generate Attributes" from_port="original" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_port="result 2"/>
<portSpacing port="sink_result 2" spacing="72"/>
</process>
</process>
